Go to Post Most importantly, get some sleep. - Libby K [more]
Unread 03-12-2016, 21:38
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
Exhaust in Solenoids
Hey Teams!
Is there any way to block the exhaust holes on the sides of the solenoids (some screw or contraption)? We are trying to program a piston to move out and in and found the exhaust hole leaking out air.
Also, if we want to control both the A and the B holes, do we need a double solenoid? Or can we make do with a single solenoid?
Sorry about these simple questions; we are a new team and are trying to figure out all of these new components. We greatly appreciate your help.
Thanks,
Charging Champions
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 03-12-2016, 21:59
Re: Exhaust in Solenoids
If you plug the exhaust ports, then the solenoid will cease to work. It only works by letting air out of the cylinder through the exhaust ports.
If air is leaking, then it is for other reasons.
Both double and single solenoids control all ports.
The difference between the two types is that a single solenoid has a home position it always returns to when power is cut or the robot is Disabled, while the double solenoid stays in the last position you put it when power is cut or the robot is Disabled.
What model solenoid are you trying to use?
Unread 03-12-2016, 22:59
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
To maybe fix the leak, try checking the ends of the air tubes, and see if they're cut straight. If they've been cut at an angle, they can leak. Cutting them straight should fix it. Note that this may not be the issue, but it's a simple thing to check before you disassemble the whole pneumatics system. Just make sure to vent any air in the tank before working on anything!
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 03-12-2016, 23:26
headlight headlight is offline
headlight is an unknown quantity at this point
A single solenoid should be enough to control both the A and B ports. The important thing is that it is a 4/5 port solenoid.
If there is air leaking out of the exhaust port it is usually either an internal leak in the seal of the air cylinder or a leak in the gasket between the solenoid and the manifold block (if you are using a manifold setup).
Unread 04-12-2016, 00:06
We are using the solenoids from this link: http://www.wcproducts.net/pneumatics.
So we are trying to control a piston that is plugged in to one of the A ports (the solenoid is connected to port 0). It seems that if we don't block off the exhaust, the air tanks don't build up in pressure as all of the air leaks out of the solenoid exhaust. In our current setup, we have our compressor connected to our compressor and a regulator. The regulator is connected to the solenoids. Is something wrong with our setup that would cause this issue?
Our air tubes seem to be cut straight, so that shouldn't be an issue, but thanks for letting us know for future reference!
Our solenoids are 4 port solenoids. We have a picture attached for what our setup looks like.
Thanks,
Charging Champions
FTC Team #8660
Unread 04-12-2016, 00:43
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Arent pneumatics not allowed in ftc?
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 04-12-2016, 03:59
Thanks,
Charging Champions
Looks good. We use that exact same setup on our FRC robot. How bad is the leak? I'm curious about what you have plugged into the B ports on the left side, and why there aren't corresponding tubes in the A ports. Also, are you feeding air into the threaded "P" port on the side of the manifold not shown in that picture?
Can you tell which exhaust the air is leaking out of? EA or EB? If you manually trigger each solenoid, does it switch which port it is leaking out of? This would be a way to narrow down which part of the circuit has the problem.
If I were trying to fix this I would unscrew each solenoid and wipe off the gasket and the mounting surface, then carefully re-mount them, alternately tightening the two screws to reduce the chance of the solenoid sitting crooked. We have also had the rare instance where the solenoid was leaking internally.
Unread 04-12-2016, 06:17
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
I agree with what Mark has said if one input port is distributing air to 2 output ports with both output ports sending air to a cylinder (one for push and one for pull).
If you have constructed a system where no pneumatic air is used to retract the piston, then you will need a stopper on one valve port.
For example: if only one port on the cylinder is connected to a valve, when that valve is diverting air to the other output port (say port 4), all connected air stores will be dumped. In this case adding a stopper plug to port 4 and making that port the "home" port will stop air from exiting when the system is being pressurized.
This kind of set up can be used to save air when the cylinder has a return spring or other method of returning the piston to its starting position.
A stopper can be made with a round urethane belt (tube) or use a tee fitting and connect 2 of the openings together with one tube to make a dead end, then connect the tee to your valve port.
Dave
Unread 04-12-2016, 16:32
We are an FRC team. Its just that the account that we are using right now is the one we used last year when we were an FTC team . Sorry about the confusion.
I'm not exactly sure if there is a leak. It seems that we are only able to control the A ports on the solenoid. We are not able to control the B ports, so the air keeps leaking out of there and makes the A ports useless.
Here is our code. Let us know where we are making a mistake:
package org.usfirst.frc.team6560.robot;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.*;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class Robot extends IterativeRobot {
   static final long TIME = 10000; // ms
   static final int SAMPLE_COMPRESSOR = 0;
   Compressor sample_compressor;
   long m_autoStartTime;
   long m_autoStartTime1;
   long m_autoStartTime2;
   Solenoid solenoid_0;
   Solenoid solenoid_1;
   Solenoid solenoid_2;
   Solenoid solenoid_3;
   public void robotInit() {
       sample_compressor = new Compressor(SAMPLE_COMPRESSOR);
       solenoid_0 = new Solenoid(0);
       solenoid_1 = new Solenoid(1);
       solenoid_2 = new Solenoid(2);
       solenoid_3 = new Solenoid(3);
   public void autonomousInit() {
       m_autoStartTime = System.currentTimeMillis();
   public void autonomousPeriodic() {
	   solenoid_0.set(true);
	   solenoid_1.set(true);
	   solenoid_2.set(true);
	   solenoid_3.set(true);
Thanks,
Charging Champions
FTC Team #8660
Unread 04-12-2016, 16:36
For a single solenoid
if
solenoid_0.set(true); - seems to be activating your A port (B port off)
then
solenoid_0.set(false); - would switch to activate the B port (A port off)
P.S.
You want to watch what the individual indicator lights are doing on the Pneumatic Control Module (PCM).
If your software works correctly, the status light for each solenoid will be (could be the reverse of this):
  • lit=port A deactivated/port B activated
  • unlit= port A activated/port B deactivated
And you should be able to see them change as your code changes the solenoid from true to false to true.
Once you are sure your code is doing what it is supposed to be doing, then look at the plumbing on the manifold. But make sure your code is operating correctly first.
Unread 04-12-2016, 16:56
Each solenoid only has two states.
State 1: Port A is connected to supply Pressure (P), Port B is connected to Exhaust B (EB).
State 2: Port B is connected to supply Pressure (P), Port A is connected to Exhaust A (EA).
With the solenoids you are using, one of these states will be the default. If you are using air cylinders that are powered in both directions by air you should have tubes running to both A and B ports. If you are using air cylinders that are not powered by air in both directions, then you should plug the unused port. I'm personally a fan of these plugs, but some people like these better. You can also get them from here.
Unread 04-12-2016, 17:24
if
then
P.S.
Does activated mean open or closed valve?
FTC Team #8660
Unread 04-12-2016, 17:49
You can think of the one solenoid as two valves that always do the opposite of each other, or as a single value with two positions.
In one position (deactivated), it is trying to fill one end of a cylinder (let's call it cylinder end A) by sending pressurized air out port A, simultaneously it is trying to empty the other end of the cylinder (let's call it cylinder end B) by releasing the other pressurized end out an exhaust port.
In the opposite position (activated), it reverses the cylinder action by sending pressurized air through port B to fill cylinder end B, while simultaneously emptying cylinder end A by connecting port A to an exhaust port.
Unread 04-12-2016, 18:03
We tested it out, and we have no control over any of the valves, even though we used the same code mentioned above and the solenoids are lighting up...
FTC Team #8660
Unread 04-12-2016, 18:08
Do we need to manually lock the solenoids to property use it (the lock mechanism is the blue screw)?
FTC Team #8660
