Go to Post Wait, crap... totally forgot that I needed to build an intake. :eek: - Andrew Schreiber [more]
Unread 12-03-2016, 11:51 PM
Re: 1.1 Pump (am-3227) Really an improvement?
Originally Posted by JPBlacksmiths View Post
How did you attach this fan being that the compressor doesn't have mounting holes for a fan? (Or at least i'm pretty sure it doesn't)
We zip-tied the little muffin fan on. It's stupid simple and worked great.
Unread 12-04-2016, 06:57 AM
Gdeaver Gdeaver is offline
FRC #1640
We just put 4 bolts and zip tied around them. Sounds like a kludge , but it works. Best to have the fan on top. That's the hottest part. This would be a good CAD - 3d printing project to make a clip on fan shroud. Post to thingiverse.
Unread 12-05-2016, 10:34 AM
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Just got off the phone with andymark... they are testing the 1.1 and the older compressor today side by side type test @ 12v so teams will have better numbers to base their decision
Unread 12-05-2016, 10:45 AM
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The problem with the claims of flow rates is that they typically ignore the critical element of temperature. We do not always operate at ambient temp. Our robot compressors are usually too hot to touch for back-to-back matches, meaning it is tougher to compress air than they typical duty cycle compressor. I suspect that the AndyMark compressor, with a longer duty cycle, may do better in a typical FRC environment given its better duty cycle, but I'd like to see some numbers.
This how we do our final pneumatics tests to know if we need another tank, and it seems to work for that purpose. I don't know what it'll tell us about different compressors though:
Fill up 4 tanks -> 5 minute break -> run testbed for 2 minutes -> Record Pressure
-> 2 minute break -> fill up 4 tanks -> 2 minute break -> run testbed for 2 minutes -> Record Pressure
GitHub
Unread 12-06-2016, 09:26 AM
Billfred's Avatar
Billfred Billfred is offline
All,
We've updated both the Viair and 1.1 Pump pages with our real-world testing.
This testing was done in our shop, with a regulated 12V power supply. Same tubing, same tanks, same gauge, same everything-as-much-as-we-can-humanly-measure.
Viair Pump:
Fill Rate for Number of Clippard tanks (574 ml) to fill from 0 to 110 psi:
1 Tank = 34 Seconds
2 Tanks = 64 Seconds
3 Tanks = 103 Seconds
4 Tanks = 140 Seconds
5 Tanks = 176 Seconds
1.1 Pump:
1 Tank = 25 seconds
2 Tanks = 45 seconds
3 Tanks = 72 seconds
4 Tanks = 95 seconds
5 Tanks = 122 seconds
We're working on converting to CFM for each 10-PSI breakpoint, but I timed both 5-tank tests and the 1.1 Pump was ahead on each one of them. Hopefully, this answers the sixty-four-dollar question.
Unread 12-06-2016, 09:49 AM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Originally Posted by Billfred View Post
All,
Viair Pump:
1 Tank = 34 Seconds
1.1 Pump:
1 Tank = 25 seconds
Got to LOVE quantitative results!
Now that extra pound has solid numbers to justify it.
Is there a chance you also captured the amount of current that was being drawn at each sample point?
Unread 12-06-2016, 10:23 AM
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Thank you for running this test, real data is the best data.
Any chance you can post the set up you used for other teams to recreate. Additionally it would be fantastic if you could compare with other legal compressor on the market such as:
- Viair 250C-IG
- Old KOP Thomas
- Thomas 215
Unread 12-06-2016, 10:32 AM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
When will these go on sale for sixty-four dollars?
Richard Wallace
since 2003
Unread 12-06-2016, 10:37 AM
Nate Laverdure's Avatar
FRC #2363
Thanks for doing this testing. I agree with the above that the current should also be considered in the testing in case it reveals any significant efficiency differences between these compressor options.
Unread 12-06-2016, 11:54 AM
Michael Hill's Avatar
Michael Hill Michael Hill is online now
Thanks for testing. I'll echo current measurement requests, but I'm super happy there are test results at all. Thanks AndyMark.
Unread 12-06-2016, 11:59 AM
Jefferson Jefferson is offline
AKA: Jeff Clements
FRC #0016 (Bomb Squad)
Jefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant futureJefferson has a brilliant future
Is the inlet air filtered at all? The Viar has a filter built into the end cap, but this one seems to just be an open hole to the pump.
We had some failures from a different pump last year, and we believe it was because of our very dirty practice floor + unfiltered pump inlet.
Unread 12-06-2016, 12:05 PM
Billfred's Avatar
I have the numbers for the 1.1 Pump up to 100 PSI handy; I don't have them for the Viair.
10	10
20	11
30	11.3
40	11.8
50	12.5
60	12.8
70	13
80	13.1
90	13.1
100	13.7
- Viair 250C-IG
- Old KOP Thomas
- Thomas 215
I've attached a picture of our setup. (The tee at the bottom was connected to more Clippard tanks, as you can imagine.)
We don't have access to those other compressors, so someone would have to collect them.
Unread 12-06-2016, 12:47 PM
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
I got this:
Unread 12-06-2016, 12:53 PM
In a thread from 2015, my team posted some results comparing compressors based on initial charge time 0-120 PSI and on recharge time 100-120 PSI.
Our test set-up is shown schematically in an attachment to this old post.
Richard Wallace
since 2003
Unread 12-06-2016, 02:12 PM
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Personally I'd like to see a test similar to the one Richard posted in that other thread with a slight modification. https://www.chiefdelphi.com/forums/a...3&d=1423070065
I'd suggest taking some plugs sized to fit the dump valve outlet and drill holes of various sizes through their end. The goal would be to create an orifice that causes the compressor to cycle on say 15-30 sec after the valve is first opened, with that particular stored volume.
Then record the cycle times over the length of a match.
It would also be interesting to see what happens when the orifice is sized so that the system is unable to build enough pressure to shut off during a normal match length. I know I've seen robots the compressor continues to run for the duration of the match either due to leaks or high demand.
Note if there are no spikes lying around a standard automotive relay could be substituted, just grab Andy's or maybe Danny's keys and borrow one. Just make sure it is for something mission critical like the fuel pump or PCM and not one they can do without like the AC compressor.
