Go to Post It's 9:00 Do you know where your bott is? - Michelle Celio [more]
Unread 04-12-2016, 16:24
ttnn58 ttnn58 is offline
FRC #4586
ttnn58 is an unknown quantity at this point
no CAN comm\damaged hardware
hello!
today we tested our electronics plate for an off-season project (first time using CAN to control motors, using 6 talon SRXs) but the status LEDs on all of the talons and on the PDP were indicating that there is a problem.
they were altering between two states:
the first one was slow red blinking, indicating damaged hardware, and the second one was altering between red and orange, indicating that there was no CAN communication.
every wire is connected where it should be, and they are all soldered properly, but still, the status LEDs indicated those problems.
I am 99% sure that all of the devices are not damaged because we took them of a robot that did worked fine (with PWM communication), and they probably were not damaged during the process.....
anyone has a clue about what the problem could be?
thank you and good night!
Unread 04-12-2016, 17:08
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumni
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Re: no CAN comm\damaged hardware
To clarify the blink codes, alternating between off/red is indicating that the CAN bus/PWM is not detected and alternating between red/orange is damaged hardware. If you guys haven't been already, refer to the Talon SRX user-guide.
The TalonSRX's may not properly configured and multiple Talons may have the same device ID because of that. The roboRIO web utility can help make sure all Talons have unused device ID's so they don't get confused on robot boot-up. Also, verify that the RoboRio on the robot you guys moved the speed controllers has the latest firmware and imaging.
If you guys have time to put the speed controllers back on the robot that they worked on, I suggest you guys try that to ensure that the speed controllers aren't actually damaged.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 04-12-2016, 17:23
FRC #4586
thanks for the quick reply!
i probably mixed the blink codes in my head
we never used CAN for talons, so every one of their IDs is probably 0, which might cause this problem. i will change it tomorrow.
anyway, do you think this problem will cause the LEDs to indicate damaged hardware?
Unread 04-12-2016, 17:28
Team 2052 Alumni
AKA: Kshitij Wavre
No problem!
I'm actually not sure whether it will cause the LEDs to indicate damaged hardware. But since you indicated that you guys pulled out working Talon SRX's in good condition, it seems odd to me they would suddenly blink like that. Also on the previous robot you guys used the Talons via PWM and never have used it in CAN, so configuration could likely be the issue.
Tell me how trying to resolve it tomorrow goes!
Unread 04-12-2016, 19:07
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
IIRC switching between orange and red happened to us once when we accidentally crimped one of our connectors backwards, resulting in the last segment of the CAN bus that ended at the PDP being connected backwards (yellow to green and green to yellow). Double check the colors
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 04-12-2016, 19:24
ctt956 ctt956 is offline
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
This gives me an idea...Maybe try using just one Talon and see if that works? Then add another one, and another until it stops working. I haven't worked with CAN extensively, but that seems like it could help you find out if the ID's are set up incorrectly.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 05-12-2016, 12:53
FRC #4586
No problem!
I changed the IDs so they won't override each other and it is working now.
thank you from team PRIMO 4586!
Unread 06-12-2016, 14:42
Team 2052 Alumni
AKA: Kshitij Wavre
No problem! Glad it worked.
