Go to Post Including the Kinect in the kit a parts is actually an evil plan. The programers are going to spend all their time playing with the Kinect. In competition the robot is just to sit there because it will not have a program. :ahh: - FrankJ [more]
Unread 05-12-2016, 14:08
GRSICP GRSICP is offline
Greta Rauch
FRC #5822 (WolfByte)
GRSICP is an unknown quantity at this point
Encoders for Drive Train
Hi Everyone!
We are hoping to put encoders on our drive train this year. We expect to again use the Toughbox Mini Gear Boxes on our drive train (http://www.andymark.com/product-p/am-0654.htm). We are having trouble determining which encoders to buy. We have limited tools and machining ability so we want to purchase something we know we can install successfully but will provide accurate and precise readings.
We had hoped to use a CTR encoder, but those seem to be out of our league in terms of installation. We liked the E4T OEM Miniature Optical Encoders from AndyMark (http://www.andymark.com/E4T-OEM-Mini...-p/am-3132.htm) but even after reading the installation instructions, we still weren't quite sure if installing this encoder would require machining capabilities. We also thought about purchasing some CIMCoders (http://www.andymark.com/encoder-p/am-3314.htm) but weren't sure if those would work with the Toughbox.
Which encoder do you recommend we purchase?
Thanks for the help!
Greta
Unread 05-12-2016, 14:13
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is online now
Registered Muser
Cothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond reputeCothron Theiss has a reputation beyond repute
Re: Encoders for Drive Train
Have you checked out the other thread for drivetrain encoders?
Unread 05-12-2016, 14:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The E4Ts do not require any machining. IIRC from our installations, you just need a screwdriver and steady hands. The hardest part is making the press fit of the hub disk (step 4), but its definitely doable by hand. It is easiest to do the install before you start filling up the inside of the chassis with electronics and such. (Also, rotate the chassis/gearbox so the output shaft is down and the encoder shaft is up.)
Edit: However, I do suggest this installation take place AFTER breaking in the gearbox dry and then greasing the gearbox!
Unread 05-12-2016, 14:20
mastachyra's Avatar
mastachyra mastachyra is online now
FRC #2781 (RoboPride)
mastachyra is just really nicemastachyra is just really nicemastachyra is just really nicemastachyra is just really nice
i agree with GeeTwo. Go with the E4T encoders. Easy install, The toughboxes actually have predrilled holes that seem to be made for the E4T.
They also seem to be pretty accurate and robust enough for our applications.
2014: EtaBot - MWR/30th place/no PO
2015: ThetaBot - MWR/30th place/no PO, R2OC/Winners, IndyRAGE 5th Alliance, WMRI QF
2016: IotaBot - MWR/16th place/QF, R2OC/7th Alliance Captain/QF, Boiler Bot Battle/6th place/Finalist
