Re: Sudden loss of comms
It is probably an issue with your code. Can you post it?
Edit: What motor controllers are you using? Last edited by Lireal : 05-12-2016 at 18:44. |
Will post code soon. |
Would it be possible that we are trying to send values over 1 or under -1 to the Victors, and that's what crashes the code?
Is it possible that your battery is not fully charged (or even if it is fully charged) the bot may be browning out when you go full throttle and dropping power to the radio?
Do you get the same behavior on the bench? If so, that would tend to point to a software or Comms issue. If not, more likely due to a brownout or acceleration issue.
Can you post the full error that you receive on the Driver Station? That will determine whether it is a code issue, or perhaps hardware.
#7
What would the suggested solution here be? Would doing a trapezoidal acceleration curve help, instead of an instant jump to high values? |
#8
Edit: On the flip side, if you're still looking for the issue, do not use ramping, as it may mask the symptoms. Last edited by GeeTwo : 06-12-2016 at 15:51. |
#9
If it is not happening on the bench/blocks, that leads me to believe it is power related.
The first question I have is: Do Comms return if you just wait 30-45 seconds? If so, the power to the radio is suspect. Second question: Do Comms return after only 15 seconds? If so, power to the RoboRio is suspect. Make sure you are powering both according to the documentation. Check your drive train for binding. Binding can cause the motors to draw too much current and brownout the system. |
#10
The Driver Station log has a lot of messages and data clues to what is happening.
