Go to Post Things go wrong; it happens to the best of us. You learn from it and move on. - Waynep [more]
Unread 05-12-2016, 19:08
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Re: Sudden loss of comms
Would it be possible that we are trying to send values over 1 or under -1 to the Victors, and that's what crashes the code?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 05-12-2016, 20:10
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Is it possible that your battery is not fully charged (or even if it is fully charged) the bot may be browning out when you go full throttle and dropping power to the radio?
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 05-12-2016, 21:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Do you get the same behavior on the bench? If so, that would tend to point to a software or Comms issue. If not, more likely due to a brownout or acceleration issue.
Unread 06-12-2016, 00:59
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Can you post the full error that you receive on the Driver Station? That will determine whether it is a code issue, or perhaps hardware.
Unread 06-12-2016, 14:51
Tottanka's Avatar
AKA: Liron Gurvitz
It doesnt happen on the bench, therefore we are now confident it is an acceleration issue.
What would the suggested solution here be? Would doing a trapezoidal acceleration curve help, instead of an instant jump to high values?
Unread 06-12-2016, 14:56
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The ramping function built into WPIlib (and I believe also LV) should at least mitigate either issue; worth a shot!
Edit: On the flip side, if you're still looking for the issue, do not use ramping, as it may mask the symptoms.
Unread 06-12-2016, 15:09
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If it is not happening on the bench/blocks, that leads me to believe it is power related.
The first question I have is: Do Comms return if you just wait 30-45 seconds?
If so, the power to the radio is suspect.
Second question: Do Comms return after only 15 seconds?
If so, power to the RoboRio is suspect.
Make sure you are powering both according to the documentation.
Check your drive train for binding. Binding can cause the motors to draw too much current and brownout the system.
Unread 06-12-2016, 15:14
The Driver Station log has a lot of messages and data clues to what is happening.
