Go to Post Want the TL;DR of it? Keep it simple, effective, and easy to use. - Andrew Schreiber [more]
Unread 05-12-2016, 22:02
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
Re: Optimize your FIRST Choice Credits 8:30pm EST 12/5
Originally Posted by Knufire View Post
I wouldn't even get the rookie bundle, personally. I'd focus on getting the components that are
a. Required on your robot per the rules
b. Commonly used year-after-year
Electronics:
*Voltage Regulator Module
*Power Distribution Panel
Victor 888
*Victor SP
Talon SRX
Motors:
*CIM Motor
PG71 Gearmotors
Pneumatics:
*Pneumatics Control Module
*Pneumatic Pressure Switch
*Pressure Relief Valve
Compressor, Model 90C (This exact compressor isn't required by the rules, but it's one of the most commonly used.)
*Items marked are also included in your rookie Kit of Parts tote that you will receive on Kickoff. I still recommend getting these, as the motors and speed controllers you will need more of, and the other items are critical, required components that will be nice to have a backup of. This also allows you to get some sort of a test bench running that you will be able to work on outside of open bag hours.
For the pressure regulator and gauges, Automatic Direct will usually include a small voucher in the Kit of Parts, which will allow you to purchase much smaller/lighter models than the ones offered in FIRST Choice. You will also get some in your Kit of Parts tote on kickoff.
This!
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
