Go to Post Sometimes at work I fantasize about being a giant bulldozer operator. - AdamHeard [more]
Unread 06-12-2016, 00:37
Munchskull's Avatar
Munchskull Munchskull is online now
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Designing with sensors
This last year our robot had some issues with rotation sensors that I would would like to avoid this coming year. Last year we used some magnetic continuous potentiometers to determine our arm posistion. The issue became these pots had a dead zone and then would restart on the other side of the voltage. Looking back on it they were probably not the use of the sensor. My question is what sensors OTHER THAN Versa planetary encoders do people use for position track on arms and other moving parts and how do you integrate them in to your design?
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-12-2016, 00:40
Knufire Knufire is offline
Re: Designing with sensors
US Digital MA3 for absolute encoders. You can also do a normal quadrature encoder and a secondary sensor for zeroing, we did this with WCP Hall Effect sensors on our 2015 elevator.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 06-12-2016, 01:00
Munchskull's Avatar
Team Role: CAD
Are HallEffect sensors used like limit switches?
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-12-2016, 01:13
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Hall Effect sensors can be used for a variety of purposes, including limit switches and something similar to an encoder. Here's a basic overview from wikipedia.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
3D printed mounts can go almost anywhere, even after the design was built without sensors.
Others have used bent polycarb as encoder mounts to absorb shock or something.
Unread 06-12-2016, 01:20
Exactly like limit switches, but the non-contact nature makes them (IMO) much more reliable.
Unread 06-12-2016, 01:55
Munchskull's Avatar
Team Role: CAD
2015 we used a reed switch for the same thing.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-12-2016, 10:47
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is online now
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Additionally, to connect the shaft of a pot to the rotating shaft, we've used a couple of tricks: either get flexible shaft couplings (one of our mentors brought some in from work) or, if you don't have that, some pneumatic tubing with zipties at both ends works well too.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 06-12-2016, 10:53
Type's Avatar
Type Type is online now
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
My team used linear actuators to make an arm move up and down, pivoting on an axis. The linear actuator's had potentiometers but they quickly broke, so we added in physical limit switches to stop the arm from going too high (jamming the actuators) or too low (destroying bearings, sometimes jamming, messing up lead screw). We also added in a string potentiometer which actually worked very well for arm position. It isn't always good though because the housing is fragile and the string can sometimes get in the way. AndyMark sells the string potentiometer and I would highly recommend it.
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 06-12-2016, 11:39
bmammen's Avatar
bmammen bmammen is offline
AKA: Brent Mammen
FRC #5801 (Inspire)
bmammen is an unknown quantity at this point
We used the MA3-A10-250-N (AndyMark's Absolute magnetic pot) on our shooting arm and had very good luck with it, no dead zone at all. Our high goal shots, among other things, were dependent on it and we were over 80% consistent in Auto. One thing to point out is that if you use v1 of the Universal Breakouts on the Talon SRX's they only supported 3.3v sensors and would therefore give you a dead zone for that 5v pot. In version 2 they've fixed that issue.
Unread 06-12-2016, 14:08
Munchskull's Avatar
Team Role: CAD
Pictures of how you mounted these would be great. Last year we had issues of the entire POT rotating at times.
Luckily (in this case) we use the Victor SP and not Talon SRXs.
How well does this actually work? The last trick like this I tried was using hot glue and it was terrible. Right now I am leaning towards drilling and tapping the shaft for using set screws.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 06-12-2016, 14:46
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
..get flexible shaft couplings (one of our mentors brought some in from work)..
There are several varieties on FIRST Choice this year - oh, it just closed a couple of hours ago. For 1/4" to 1/4" solutions, see FC17-122, or a combination of two FC17-110s with an FC17-124 between them.
Note that to couple two 1/4" shafts with tubing, you would need tubing with a 1/4" inside diameter, not outside. I have never done this, but it seems that you would want to keep the length short if your application is sensitive to sensor backlash.
I heard secondhand (no details) about a team who used a 1/4" drive socket universal joint in a coupler to isolate a potentiometer from shock loads. Yep, sounded kludgy to me too.
Unread 06-12-2016, 17:41
Roboter
Rookie Year: 2015
Absolutely. The tubing was probably about a 3/4" plus what went on each end of the shaft. The only goal is to not have to align the pot and the shaft perfectly.
Unread 06-12-2016, 17:55
bmammen's Avatar
AKA: Brent Mammen
FRC #5801 (Inspire)
We used a lathe to bore a 1/4" hole into the end of the 1/2" hex shaft our arm was rotating on, we then slotted it on the 6 sides of the 1/2" hex shaft by making 3 cuts straight across, and finally added a collar clamp to tighten the end of the hex shaft after the encoder shaft was inserted. We simply used 2x2 angle to mount the POT in place.
If you're interested I could take pictures next time I'm up at the shop.
Unread 06-12-2016, 19:30
I've done similar as well. works with even just a single slit across. Since it's more or less a rigid coupling, good practice would be to make a somewhat flexible mount so minimal side load is put on the encoder shaft. The encoder body mount simply needs to stop the body of the encoder from rotating, not locate it. Bent 1/16" polycarbonate works well.
