Go to Post I think this just hit the nail in the head with a sledgehammer. - Yan Wang [more]
Unread 05-12-2016, 18:37
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
Sudden loss of comms
So we are running Java code on a pretty basic Tank Drive robot, and a weird issue keeps happening.
Every time we go 'full throttle' on our joysticks the robot seems to move for 0.1 sec and than goes "code error" and loses communication.
While driving with 1/2 throttle or so, everything is ok. We have checked the wiring, we have been knocking the robot pretty hard while stationary and it stays connected.
Any ideas?
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Unread 05-12-2016, 18:39
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal has a spectacular aura aboutLireal has a spectacular aura aboutLireal has a spectacular aura about
Re: Sudden loss of comms
It is probably an issue with your code. Can you post it?
Edit: What motor controllers are you using?
Unread 05-12-2016, 19:01
Tottanka's Avatar
AKA: Liron Gurvitz
We are using Victor 888s.
Will post code soon.
Unread 05-12-2016, 19:08
Tottanka's Avatar
AKA: Liron Gurvitz
Would it be possible that we are trying to send values over 1 or under -1 to the Victors, and that's what crashes the code?
Unread 05-12-2016, 20:10
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Is it possible that your battery is not fully charged (or even if it is fully charged) the bot may be browning out when you go full throttle and dropping power to the radio?
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 05-12-2016, 21:46
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Do you get the same behavior on the bench? If so, that would tend to point to a software or Comms issue. If not, more likely due to a brownout or acceleration issue.
Unread 06-12-2016, 00:59
AKA: Alex Colello
Can you post the full error that you receive on the Driver Station? That will determine whether it is a code issue, or perhaps hardware.
Unread 06-12-2016, 14:51
Tottanka's Avatar
AKA: Liron Gurvitz
It doesnt happen on the bench, therefore we are now confident it is an acceleration issue.
What would the suggested solution here be? Would doing a trapezoidal acceleration curve help, instead of an instant jump to high values?
Unread 06-12-2016, 14:56
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
The ramping function built into WPIlib (and I believe also LV) should at least mitigate either issue; worth a shot!
Edit: On the flip side, if you're still looking for the issue, do not use ramping, as it may mask the symptoms.
Unread 06-12-2016, 15:09
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
If it is not happening on the bench/blocks, that leads me to believe it is power related.
The first question I have is: Do Comms return if you just wait 30-45 seconds?
If so, the power to the radio is suspect.
Second question: Do Comms return after only 15 seconds?
If so, power to the RoboRio is suspect.
Make sure you are powering both according to the documentation.
Check your drive train for binding. Binding can cause the motors to draw too much current and brownout the system.
Unread 06-12-2016, 15:14
The Driver Station log has a lot of messages and data clues to what is happening.
Unread 18-12-2016, 22:32
kenfox kenfox is offline
FRC #3322 (Eagle Imperium)
kenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of lightkenfox is a glorious beacon of light
So we are running Java code ... We have checked the wiring ...
Any ideas?
It helps a lot if you post a photo of your wiring and a bit of your Java main teleop.
A simple mistake like powering the VRM off the user rails can cause loss of power to the radio if the roboRIO goes into self-preservation mode on low voltage. It's impossible for us to troubleshoot without seeing the wiring.
Unread 19-12-2016, 05:53
Tottanka's Avatar
AKA: Liron Gurvitz
So after some debugging, i think that it was a combination of faulty wiring to the VRM and some coding errors.
It's all solved now, and no brownouts to be seen.
Thanks!
