Go to Post GP and the Scout Law are high ideals that only the best will achieve and live everyday. - Al Skierkiewicz [more]
  #34   Spotlight this post!
Unread 06-12-2016, 16:35
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: 1.1 Pump (am-3227) Really an improvement?
Originally Posted by Tom Line View Post
Worst. Pneumatic. Puns. Ever.
Really? I thought they were a gas.
Seriously, the value of this upgrade becomes clearer when you calculate how much air you can compress in an hour. Assuming you have your pressure switch's range set so that your "average" pumping is at 100psi (and don't bleed your tanks between matches):
The 1.1: 0.31 cfm * 15% * 60 minutes = 2.79 cf/hr
Viair: 0.22cfm * 9% * 60 minutes = 1.19 cf/hr
That's about 2.3 times as much air, for $6 extra and less than a pound more!
