Go to Post One day the code will be written first, and then a robot built around it - dag0620 [more]
Unread 29-11-2016, 17:38
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
West Coast Products SS
My team is looking to use the West Coast Products SS gearbox to make a practice drive train. We have finalized everything except what type of sprockets to use in the gearbox. We noticed when you order the gearboxes from either Vex or WCP that it gives you the option for single sprockets. Has any teams tried using Double Sprockets? or is the only option to use 2 single sprockets for a West Coast Drive?
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 29-11-2016, 17:42
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: West Coast Products SS
Are you looking to use #35 chain double sprockets? Or #25 chain overall but double sprocket form?
R.C.
MadTown Robotics Team 1323
Unread 29-11-2016, 18:10
Type's Avatar
Rookie Year: 2016
We are looking to use #35 chain
Unread 29-11-2016, 19:38
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
You should be able to make double sprockets work, if that's the case. What makes you think they won't work the same as two singles?
Unread 29-11-2016, 19:47
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
See step 6 of the assembly instructions for the WCP SS West Coast Drive gearbox. Any configuration of sprockets, pulleys, and spacers can be used so long as it adds up to 2.25" and the chain/belts do not rub on the gears or face plates. The provided illustration shows two single sprockets being used in a fashion that allows the inboard chain run a little more space away from the 2nd stage of reduction. I believe this is the assembly method that 1712 used in 2016 for our drivetrain since it facilitated better chain runs elsewhere in our drivetrain (pushing the inboard chain slightly outboard gave us a tiny bit more bellypan real estate).
Unread 06-12-2016, 22:31
PeterK PeterK is offline
FRC #4537 (RoboRoos)
Rookie Year: 2015
PeterK is an unknown quantity at this point
Any idea when these gearboxes will be back in stock?
Unread 06-12-2016, 22:33
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Per another thread:
Originally Posted by Andrew_L View Post
Give it a couple of weeks - I believe RC mentioned something about stock coming in within the next two to three weeks in another thread.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 06-12-2016, 22:48
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Remember that the output shaft is 1/2" hex. The VEX / WCP single sprockets have this bore, making it very easy to install them.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 07-12-2016, 00:02
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Just checked our 2016 machine tonight, and it does use a #35 12t double sprocket. The clearance is a bit tight between the chain, but it's nothing to be worried about if you plan ahead.
They also have double sprockets with .500 hex bore.
Unread 07-12-2016, 07:32
Type's Avatar
Rookie Year: 2016
We found some gearboxes from Robot Space, but the gear selection was sparse. We Cadded it up to see if it would fit, and after physically putting it in last night, the 12t Double Sprocket #35 will fit, it is tight but it will fit with the correct spacers. I believe once we finish up the basic drivetrain, my team will be posting a picture.
