Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
  #38   Spotlight this post!
Unread 07-12-2016, 08:52
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: 1.1 Pump (am-3227) Really an improvement?
Originally Posted by Andy Baker View Post
As Billfred mentioned previously, we will test any reasonable pump on this same bench test. I *might* have an old KOP Thomas. I don't have the others. If you send them to me, I will test, post the results here, and then send them back. Put a note in the box saying "pump test" and give me your return address. Send to "AndyMark Pump Test, 2311 N. Washington St. Kokomo, IN 46901". Heck, we may even send the pump back with some surprises.
Andy, I just ordered a new Thomas 215 and had it delivered to AndyMark. We've been meaning to try one and this seems like the perfect time. Thanks for running these tests, I'll PM you a return address.
Originally Posted by AllenGregoryIV View Post
Spectrum is sending you a Viair 98C should be in the mail tomorrow. This was ordered from Amazon on January 28, 2016 and is labeled 1.10CFM at 13.8V. I'm really curious what it will actually test at for 12V, seeing as now the Viair website lists this model at 1.53 CFM.
We also have two of these compressors with the old label on the body. They are a nice compressor and we were disappointed when Viair changed the ratings on the website. It called into question if we should run them in the future given the difference in labeling. Happy to see this one will get bench marked as well.
