Go to Post We live for those eureka moments. Whether we win or lose competitions, it's those moments when a student's idea makes something just "click" that will stick with them and influence them to become engineers. - ToddF [more]
  #31   Spotlight this post!
Unread 22-11-2016, 21:13
inorbert inorbert is offline
Build Captain and Driver
FRC #5811 (BONDS)
Team Role: Driver
Rookie Year: 2016
inorbert is an unknown quantity at this point
Originally Posted by Nuttyman54 View Post
Veteran teams (aka, not rookie teams) do not get a control system in their Kickoff Kit, so I would recommend you pick up those components on FIRST Choice.
If you click on the links to the various FIRST Choice components, they will say if they are in the Kickoff Kit or not. There are three options - "Yes", "No" and "Rookie Tote Only", so they make it easy to tell what stuff on FIRST Choice each team will also be getting in their Kickoff Kit.
You can also look at the 2016 kickoff kit inventory sheets and look at what was in the Yellow Tote. Those were "rookie only" items last year (veteran teams did not get a yellow tote). 2017 kit contents will be somewhat different but it's a good baseline to see what stuff you might want to pick up before the season that's not available on FIRST Choice.
Thank you, much appreciated
Sent from my LG-D851 using Tapatalk
  #32   Spotlight this post!
Unread 02-12-2016, 15:49
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
Re: [FRC Blog] FIRST Choice 2017
What would you think is a better choice to go with the NavX micro (http://firstchoicebyandymark.com/fc17-074) or the ADIS option (http://firstchoicebyandymark.com/fc17-007). Thank You!
  #33   Spotlight this post!
Unread 02-12-2016, 16:29
Nate Laverdure's Avatar
FRC #2363
The navX-Micro processes data from its onboard sensors to provide a "fused heading" whereas the ADIS16448 does not.
  #34   Spotlight this post!
Unread 02-12-2016, 18:59
slibert slibert is online now
Software Mentor
AKA: Scott Libert
FRC #2465 (Kauaibots)
slibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud ofslibert has much to be proud of
Full disclosure: As founder of Kauai Labs, I'm biased towards the navX-Micro so you should take this w/a grain of salt - but I wanted to toss out a couple of system-level considerations.
A few features the navX-Micro has you might consider useful are it's dual simultaneous interfaces (I2C and USB), which allow you to:
- Connect I2C to RoboRIO, and USB to your vision processor (to share the high-resolution timestamp and IMU data w/both processors simultaneously), and
- Connect USB to RoboRIO and mount the navX-Micro USB anywhere on the robot (USB supports up to a 6 meter range).
One other distinction is that navX-Micro has a dual power supply (5V on the I2C pins, and 5V on the USB interface), whereas the ADIS16448 MXP board (based upon the published schematic) does not.
If a MXP board doesn't provide a secondary power supply, it's only power supply (from the RoboRIO) is subject to brownout whenever the RoboRIO voltage drops below 6.3V (even for an instant). So during that time no data is available, and since the ADIS16448 MXP Board runs the sensor fusion algorithms on the RoboRIO, these algorithms will be missing data for some period of time. For normal matches where you change out a battery before each match this is almost surely not an issue, esp. if you use the sensor only for autonomous (at the beginning of the match). But it could be an issue if you use the sensor for teleop and esp. during longer practice matches.
  #35   Spotlight this post!
Unread 07-12-2016, 08:54
maxnz's Avatar
maxnz maxnz is offline
Can't wait for next season!
AKA: Max Narvaez
FRC #2855 (BEASTBot)
Team Role: Student
Rookie Year: 2016
maxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of lightmaxnz is a glorious beacon of light
Has the algorithm finished running? I see that some things are marked as out of stock, but not as much as I thought. The same things were marked last night when I checked.
Just wondering when we will know what's left for regular ordering on Monday.
As a senior that will be leaving the team, I have to teach others how to:
1. Know the manual extremely well
2. Wire the robot
3. Organize the shop
4. Help people find parts when they need them
5. Find parts to order and give the detailed list to the coach in charge of buying the parts
6. Keep track of team updates, Q & A responses and FIRST blog posts
7. Be active on CD
8. Plan and execute drive team strategy
And more that won't fit on this list...
  #36   Spotlight this post!
Unread 07-12-2016, 09:02
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
who the heck bought all the window motor connectors
  #37   Spotlight this post!
Unread 07-12-2016, 09:05
Bryce Clegg's Avatar
Bryce Clegg Bryce Clegg is offline
FRC #3196 (Team SPORK)
Bryce Clegg is on a distinguished road
Originally Posted by bobbysq View Post
Does anyone remember how many there were originally?
Deans List Semi-Finalist 2016
"I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." - Woodie Flowers
  #38   Spotlight this post!
Unread 07-12-2016, 09:18
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
99
  #39   Spotlight this post!
Unread 07-12-2016, 09:41
I like how the quantities of some items actually increased, e.g., Mounting bracket (fc17-142) (started @ 1000).
Is there a trade-in program I overlooked? :-)
  #40   Spotlight this post!
Unread 07-12-2016, 10:16
Mr. Ackroyd's Avatar
Mr. Ackroyd Mr. Ackroyd is offline
FRC #3044 (OxBe4)
Mr. Ackroyd is on a distinguished road
Looking at the priority list, it's incredible the amount of items out sold out for 2017. One that jumps out at me are the talon's. I'm glad we stocked up on them earlier in the summer.
2016 CMP Tesla division Quaterfinals
2016 Finger Lakes Regional: Finalist on Alliance 3 (4930, 3044, 340) Industrial Design Award, Industrial Safety Award, Wildcard
2016 NYTVR: Quarterfinals on Alliance 8 (4930, 3044, 4481), Team Spirit Award
2015 Finger Lakes Regional Entrepreneurship award
2015 New York Tech Valley Regional FIRST Dean's List Finalist Award
2014 Finger Lakes Regional Industrial Safety Award, Team Spirit Award, Regional Finalists
2014 New York Tech Valley Regional Team Spirit Award
2013 WPI Regional Regional Winners, Team Spirit Award
2012 Finger Lakes Regional Regional Finalists
  #41   Spotlight this post!
Unread 07-12-2016, 10:24
maxnz's Avatar
AKA: Max Narvaez
Team Role: Student
Rookie Year: 2016
I would say that talons were understandable. What I'm surprised about is that the core control system components haven't been marked sold out yet.
2. Wire the robot
7. Be active on CD
  #42   Spotlight this post!
Unread 07-12-2016, 12:49
Apparently, the PDP and VRM both started out at 1,000 ct. and are down to 256 and 241. In comparison, the talons started out at 2500 and are sold out. I'm confused by it as well.
  #43   Spotlight this post!
Unread 07-12-2016, 12:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It's not that confusing. Let's say there were 700 teams that wanted all of the control system stuff. They all out the PDP's and VRM's on there at 1 each. They also put talons on their list at 4 each. 700x4 is more than 2500!. Due to the increased limit per team, they were bound to sell out.
2016: Lake Superior WFFA
  #44   Spotlight this post!
Unread 07-12-2016, 15:23
Michael Hill's Avatar
Sounds like we've got a good amount of thin 1/2" shaft collars coming to us, in all sorts of colors!
  #45   Spotlight this post!
Unread 07-12-2016, 16:34
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is online now
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Originally Posted by GeeTwo View Post
It looks like the results of the first round draft are available on the first choice site. Log in, go to MY ACCOUNT on the top bar, then Orders on the left, then Order Details on the right. You can also see how much shipping you were charged.
If it isn't up, wait a bit, they may still be populating.
Ours isn't up yet. Does it have full items that you received or just shipping charges?
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
