Go to Post Don't ever give up on your robot, especially this early in the season. That robot is what you make of it. If you give it your all, something good is bound to come your way. - Amanda Morrison [more]
Unread 07-12-2016, 14:31
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Velocity PID(F) Best Practices - To Integrate, or Not To Integrate?
So, here's a graph of our flywheel velocity error (units in RPS) versus time during a shooting test. The negative spikes are slowdown while the flywheel is in contact with the ball. The velocity setpoint was 50 RPS.
As we can see, consistent with the above discussion, there is steady-state error, but it is very small.
We are wondering if teams bother to introduce any integral gain to eliminate the steady-state error, and if this performance is consistent with what other people have seen using similar methods.
"The breakfast of champions!"
Unread 07-12-2016, 18:59
Bryce2471's Avatar
Bryce2471 Bryce2471 is offline
Alumnus
AKA: Bryce Croucher
FRC #2471 (Team Mean Machine)
Bryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud ofBryce2471 has much to be proud of
Great data. Thanks for that contribution. I have a couple questions:
How long did you wait between shots?
How much was the steady state error effected when you changed the set point.
How much time, or how many iterations did you spend tuning the Kf value? How about Kp?
Thanks again.
FLL Team Future imagineers
2010 Oregon State Championships: Winners
2011 International Invite: First place Robot design, Second Place Robot Performance
FRC Team Mean Machine
2012 Seattle: Winning alliance
2013 Portland: Winning alliance
2013 Spokane: Winning alliance
2014 Wilsonville: Winning alliance
2014 Worlds: Deans List Winner
Unread 07-12-2016, 19:20
AKA: Eli Barnett
Thanks again.
1) We didn't time this precisely, but it was on the order of 10 seconds.
2) We haven't rigorously tested this yet, will report back once we have data
3) We tested our flywheel speed at max voltage, and then simply naively set Kf to (max output)/(max speed). We did not test across multiple battery voltages or setpoints - if anyone has suggestions for a good systematic way to do this, it'd be appreciated.
4) We started Kp pretty small and then doubled it until we started to see oscillations, at which point we set it to halfway between that and the previous value. There were a couple more iterations after that, I think, but I don't recall exactly how many.
All in all, it was a pretty "rough" tuning procedure - we were mostly interested in getting it working, with the understanding that we can fine-tune it later.
Originally Posted by Jared Russell View Post
We didn't use integral gain, but we did use some derivative gain to lessen the initial overshoot, and a 36V/s rate limit to smooth things out a bit:
https://github.com/Team254/FRC-2016-...ants.java#L152
(Talons were in coast mode as well)
We allowed firing whenever our flywheel was within 100rpm (1.67rps) of our setpoint because we found it made no practical difference to our shot trajectory. In practice, most shots we took were within 20rpm of our setpoint. If you are within .1rps (6rpm) steady-state, I'd say you're already in good shape.
Thanks a bunch for all of your input - it's greatly appreciated. I'll add these to the list of things to try.
Hopefully we'll find some time to sit down and really play with different tuning schemes, and record the data.
Unread 08-12-2016, 01:03
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
I'm the person who implemented the velocity PID controller in WPILib last summer. If I understand correctly, an integrator is necessary and sufficient to eliminate steady-state error in controlling a DC motor with a velocity PID controller in all cases. Here's some math:
I'll be using the model for a DC motor from http://ctms.engin.umich.edu/CTMS/ind...stemModelin g, which has the following transfer function from voltage (V) to angular velocity (theta_dot):
P(s) = theta_dot(s)/V(s)=K/((Js+b)(Ls+R)+K^2)
First, we'll try controlling it with a P controller defined as:
C(s) = Kp
When these are in unity feedback, the transfer function from the input voltage to the error is:
E(s)/V(s) = 1/(1+C(s)P(s))
E(s) = 1/(1+C(s)P(s))*V(s)
= 1/(1+Kp*K/((Js+b)(Ls+R)+K^2))*V(s)
(See http://ctms.engin.umich.edu/CTMS/Con...motorBlock.png for a diagram. I'm assuming that theta_dot_ref maps to the input voltage with a constant gain and that the measured signal is used as-is in the error calculation, so H(s) = 1).
In this case, we'll apply a step input, so V(s) = 1/s.
E(s) = 1/(1+Kp*K/((Js+b)(Ls+R)+K^2))*1/s
To find the steady-state value of a transfer function, we can apply the formula:
e_ss = lim_s->0 s*E(s)
e_ss = lim_s->0 s*1/(1+Kp*K/((Js+b)(Ls+R)+K^2))*1/s
= lim_s->0 1/(1+Kp*K/((Js+b)(Ls+R)+K^2))
= 1/(1+Kp*K/((0+b)(0+R)+K^2))
= 1/(1+Kp*K/(bR+K^2))
Notice that the steady-state error is non-zero. To fix this, an integrator must be included in the controller:
C(s) = Kp+Ki/s
Same steady-state calculations as before with the new controller:
= 1/(1+(Kp+Ki/s)*K/((Js+b)(Ls+R)+K^2))*1/s
e_ss = lim_s->0 s(1/(1+(Kp+Ki/s)*K/((Js+b)(Ls+R)+K^2))*1/s)
= lim_s->0 1/(1+(Kp+Ki/s)*K/((Js+b)(Ls+R)+K^2))
multiplying by s/s:
= lim_s->0 s/(s+(Kp*s+Ki)*K/((Js+b)(Ls+R)+K^2))
= 0/(0+(0+Ki)*K/((0+b)(0+R)+K^2))
= 0/(Ki*K/(bR+K^2))
the denominator is non-zero, so e_ss = 0.
So mathematically speaking, an integrator is required to eliminate steady-state error in all cases for this model. If you don't want to use one, a feedforward can eliminate most if not all of the error if chosen carefully. Given that, there is always uncertainty, hence why feedback control exists.
Oblarg is correct that the behavior of the velocity PID tuning constants doesn't match the displacement PID. I tried to get something with close enough dynamics that teams could use a similar tuning procedure for both (except in the velocity case, there's no steady-state error so I made Ki not do anything).
Unread 08-12-2016, 01:16
AdamHeard's Avatar
Lead Mentor
In the practical sense most teams are just looking for consistent RPM within a tight band near the setpoint.
If the system inertia is large enough compared to the motor power and the control frequency high enough you'll get high frequency oscillations of low magnitude around the setpoint (as Jared and Oblarg detailed above).
So, you need an integrator to eliminate steady state error in a theoretical sense, but not necessarily in a practical sense depending on the system.
Unread 08-12-2016, 01:45
Jared Russell's Avatar
Taking a year (mostly) off
This is totally reasonable, and in practice you need an integrator if your loop rate is slow or you are concerned about the effects of rapid oscillation on the lifetime of your mechanical components.
e_ss = 1/(1+Kp*K/(bR+K^2))
e_ss approaches zero as Kp approaches infinity, and the closed-loop transfer function is stable for all positive values of Kp.
Unread 08-12-2016, 02:02
AKA: Eli Barnett
C(s) = Kp
C(s) = Kp+Ki/s
multiplying by s/s:
= 0/(Ki*K/(bR+K^2))
This is basically what I had figured after reading up on control theory over the past few days. The WPILib implementation certainly works (it is essentially what my team did for our drive last year); however, I don't know if anyone has any good data on how it performs c.f. the other method.
I'd like, when I find the time, to run some actual tests and find out what the practical difference in performance is between the two approaches in FRC contexts.
I know the WPILib implementation runs in its own thread and the loop frequency can be set manually - do you know what the fastest speed it can run is?
Unread 10-12-2016, 01:54
If you want to run it much faster than 100 hz, you should start looking at monitoring the between-loop timing, and improve it. By default, WPILib threads don't run with SCHED_FIFO priority, so they can have a bit of timing jitter. We write our own to get full control, and can reliably hit +- 280 uS with a 5 ms loop. Without that, we've seen it miss cycles.
As you get faster and faster, you'll start to see noise show up in the velocity measurement due to the discrete differentiation. When that starts to happen, you'll need to add complexity to filter it out.
Unread 10-12-2016, 12:17
AKA: Eli Barnett
What kind of filtering do people typically use? Would exponential smoothing suffice?
Unread 10-12-2016, 15:21
I'm pretty certain that 971 is not typical, but we run either a statespace observer or kalman filter to smooth the velocity out (Practically speaking, they are just different ways to do the same thing with different knobs). Most teams seem to just use PIDF (if they use anything at all).
The math for an observer boils down to
X_hat(n + 1) = A X_hat(n) + B u(n) + L * (Y - C X_hat(n))
A and B are derived from your model. C is the mapping from your state to your sensor readings. X_hat is the estimate of the state. Y is your sensor measurement, and L is the feedback gain that you get from tuning the filter.
I'm happy to go into more details if you are interested, and our code to implement this is publically available.
Unread 10-12-2016, 17:49
calcmogul's Avatar
WPILib Developer
AKA: Tyler Veness
If you don't have a model to use with a state space observer, that's a good alternative. WPILib has a LinearDigitalFilter class that implements PIDSource, so it can be used with WPILib's PID controller. You can either use the exponential smoothing (single pole IIR) and moving average factory methods or design your own filter and pass the gains in.
For example, to find the gains for the single pole IIR filter, we discretized the transfer function Y(s)/X(s) = 1/(1+s*tau) where tau is the time constant. The cutoff frequency can be obtained with f_c = 1/(2*pi*tau).
I should warn you we tried using the moving average filter with a buffer length of 50 in the velocity PID controller (instead of a std::queue of length 50) and it failed WPILib's integration tests. I haven't had time to determine why, but my current guess is floating point precision errors from adding so many values together. More testing is needed.
Unread 11-12-2016, 16:21
Note that the Talon SRX does velocity filtering for you (IIRC a 64-tap FIR filter, where each value is the change in position over the preceding 100 milliseconds, and the filter is updated at 1KHz).
Unread 11-12-2016, 17:49
AKA: Eli Barnett
Out of curiosity, what does the window function look like? Flat moving average, or?
Unread 11-12-2016, 18:00
I assume flat moving average, but not positive.
Unread 07-12-2016, 19:11
