Go to Post Welcome to CD! You'll find this is basically the coolest place on the internet. - Donut [more]
Unread 12-08-2016, 07:55 AM
James3245 James3245 is offline
FRC #3245 (Ravens)
James3245 is on a distinguished road
drilling larger holes in aluminum
We do a fair amount of drilling holes in 1x2in tube stock. Sometimes many holes for lightening purposes. We've succeeded various ways - I'd like to know what is best practice with:
3/4in and larger diameter holes in 1/8in aluminum stock
Two specific questions when using a drill press:
a. what drill bit is best? hole saw bit, large drill bit, step drill bit, other
b. what is best technique? (pilot hole? oil? other recs.)
I'd like to settle on one tool and technique for my team and I would appreciate advice from experienced machinists.
Thanks!
Unread 12-08-2016, 08:02 AM
jamesmcip jamesmcip is offline
It's fine, don't worry about it
AKA: James Cipolletti
FRC #4908 (Dragons)
Team Role: CAD
jamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of lightjamesmcip is a glorious beacon of light
Re: drilling larger holes in aluminum
Originally Posted by James3245 View Post
Two specific questions:
Thanks!
For larger sized holes up to about 1" or 1 1/8", we always use a step bit for very accurate holes with a nice surface finish. Anything larger than that hole saws become basically the only option.
Step bits are very quiet and smooth when sharp, but it is best practice to use oil when necessary to cool it off for a little bit. If you had to choose one tool, I would go with the step bit.
Unread 12-08-2016, 08:25 AM
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
My team actually uses a hand drill since most holes are applied after the robot is assembled. We created a block to clamp onto the side of the tube, giving a perfect located hole. I can't remember what size we go up to but we use a stepbit also, just drill a pilot hole and run the step bit through and it's very easy to make up to 1 1/8 holes atleast
3452- Lead Builder/ Pit Boss & Ambassador
*My posts do not reflect the opinion of my team*
Unread 12-08-2016, 08:27 AM
FRC #3245 (Ravens)
Is it best practice to use a starter hole or does a step bit make it unnecessary?
Unread 12-08-2016, 08:29 AM
FRC #3245 (Ravens)
And how does one achieve consistency on size of hole, if necessary, with a step drill bit?
Unread 12-08-2016, 08:51 AM
Type's Avatar
Rookie Year: 2016
I'm not sure if it is necessary, but it does make it easier in my opinion. Just a hole so when you start drilling, it doesn't move around.
And a step bit has multiple layers usually, so after you drill with one, it kinda skips to a wider layer, and you can feel that drop. So you can either count the drops, or every once in awhile stop the drill and see what number shows up for that section you are in, if that makes sense.
Unread 12-08-2016, 08:59 AM
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We haven't had to drill any lightening holes since our rookie year....best practice is to design the robot so it's light enough.
Sometimes we use hole saws to make large holes, if we need them for functional reasons. But usually if we are using aluminum square tube, it will get brackets riveted to it, or maybe it will pivot on some bolts, or something simple like that, so it won't need holes larger than maybe 3/8" diameter. We don't even have a unibit.
Unread 12-08-2016, 09:44 AM
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
We've been using these carbide hole cutters for bearing mount holes. I do recommend the hole cutter since it makes consistent holes in a drill press and bearings just slide right in there once you get the hang of drilling without applying a lot of force.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 12-08-2016, 10:08 AM
electroken's Avatar
electroken electroken is offline
Electron Tamer
AKA: Ken Pontbriant
FRC #0230 (Gaelhawks)
electroken is a jewel in the roughelectroken is a jewel in the roughelectroken is a jewel in the rough
Set the depth stop on the drill press.
Unread 12-08-2016, 10:15 AM
electroken's Avatar
Electron Tamer
AKA: Ken Pontbriant
We've used cutters like those and they work very well in aluminum. Our approach for bearing holes is a bit different. We use a 28mm cutter (a couple thousandths too small) and follow up with an adjustable reamer for a light press fit of the bearing.
Unread 12-08-2016, 10:49 AM
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you are using a step drill in a hand drill and making a lot of holes, put masking or painters tape around the step drill on the width above where you want to stop at, then just stop pushing when the masking tape touches what you are drilling into.
Art Dutra IV
世上无难事,只怕有心人.
Unread 12-08-2016, 11:57 AM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Will also recommend. It's a lot better than the other kind of hole saws that we were using before. (Which apparently were intended for wood and not metal! They worked well enough though.)
Unread 12-08-2016, 12:02 PM
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Or just get something like this and drill all the way through.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 12-08-2016, 12:35 PM
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Personally I favor these for up to 3/4" they do come larger as well
https://www.amazon.com/gp/aw/d/B0082...ScL&ref=plSrch
Unread 12-08-2016, 01:07 PM
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
Layout all your holes first, and use a center-punch to guide the drill.
For drilling through 6061 Rectangular sections, I would also recommend a hole saw. The OD of the hole saw will keep it centered in the first hole, so it can cleanly go though and makes a parallel cut in the back side. A slower cutting speed, and liberal use of cutting fluid is the best method.
Cleanup with a deburring tool
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
