Go to Post Great people like you both [Scott and Libby Ritchie] make the FIRST community even better! - tiffany34990 [more]
Unread 08-12-2016, 10:45
ahartnet's Avatar
ahartnet ahartnet is online now
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant futureahartnet has a brilliant future
Re: New AM Shrink Tube Solder
Originally Posted by electroken View Post
They do require a lot of heat to melt the solder cylinder within, much more than most wire insulation can tolerate, so some care is needed to avoid damaging the wire insulation.
I've used them at my day job (NASA). They definitely do require more heat than many other things that require a heat gun.
My use cases have been when we need to solder a wire to a braided shield (surrounding the wires). I do not know if that is the main purpose of them or not, but soldering a wire to a shield can be either tricky or difficult to provide a strong mechanical connection.
I agree with the other sentiments expressed here - if it is able to help those teams that may not have someone to teach them how to solder - great! Do I think this is particularly helpful in FRC (as opposed to butt splices, levernuts, andersons, or soldering) - eh I won't be pushing to move to these instead, but I won't deem it a poor decision by those that do.
This is what I see:
-Advantage over levernuts: cheaper
-Advantage over butt splices: stronger connection and more obvious that it's completed (crimping done by inexperienced people are likely to either crimp the wrong place, or not crimp hard enough). It is obvious (and like bilfred said - satisfying - to see the solder melt
-Advantage over Andersons: cheaper (probably, I haven't confirmed), more permanent, and same crimp issues noted before
-advantage over soldering: probably quicker, requires less experience
-disadvantage over levernuts: takes longer, requires more tools than a wire stripper (or sharp edge), requires electrical power (or battery powered heat gun)
-disadvantage over butt splices: more expensive, requires electrical power (or battery powered heat gun)
-disadvantage over andersons: can't disconnect
-disadvantage over soldering: more expensive, requires a decent check of wire on both ends (i.e. - there are some situations you can only solder to connect wires)
Team 451 The Cat Attack, Student Alumni (2005)
Team 1646 Precision Guessworks, Mentor (2006-2008)
Team 2936 Gatorzillas, Mentor (2011-2014)
Team 5414 Pearadox, Mentor (2015-Present)
Unread 08-12-2016, 11:03
Chris is me's Avatar
AKA: Pinecone
I'm glad this exists. It is an easy and mess-free way to create a strong electrical connection that anyone can visually verify is robustly held in place. I / my team might not use it, but there are a lot of situations where I would rather a team use these than try and crimp a connector with the improper tools / technique.
Unread 08-12-2016, 11:38
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Originally Posted by ahartnet View Post
This is what I see:
They actually appear to have similar unit rates using Amazon prices for the levernuts and for the heat shrink solder. These get you a better deal than AM's price.
Unread 08-12-2016, 11:56
RoboChair's Avatar
RoboChair RoboChair is online now
AKA: Devin Castellucci
What the heck are they using in their solder alloy? Full melt at 300F?
11 Years and counting! Over a third of my life has been spent with FRC.
Unread 08-12-2016, 12:22
Nate Laverdure's Avatar
FRC #2363
Maybe In97/Ag3 or Sn50/Pb32/Cd18
Are they RoHS compliant?
Unread 08-12-2016, 13:40
RoboChair's Avatar
There is no way there is profit margin in using that amount of Indium, that stuff is like $0.50 per gram, in bulk. I spent $150 for a half a pound of the stuff, but I will say I do like the taste and consistency. Always entertaining to see someone's reaction to chewing on a piece of metal.
Unread 08-12-2016, 14:08
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
As several others have noted, these have been around for a long time. I saw them for the first time back in college 25 years or so ago. In my opinion they are a fairly reliable method of joining wires. However, knowledge and experience with good soldering techniques are still required when using these. It's very easy to create a cold solder joint if you aren't careful.
Turbo Encabulator Installation and Repair
Unread 08-12-2016, 16:41
foote stepped in
AKA: E. Foote
FRC #0868
Originally Posted by ctt956 View Post
it's soldering irons that take 3-5 minutes to warm up.
Sounds like you need a better soldering iron.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 08-12-2016, 22:50
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Billfred View Post
We also released two things:
1) This how-to video so you can see the process for yourself.
Another recommended process includes mechanically interleaving strands of the two wires to be joined. Less risk of cold joint.
Richard Wallace
since 2003
Unread 08-12-2016, 23:30
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
This is what I see:
You can get these type of connectors to work properly with just a lighter or candle. Of course there is a risk with using an open flame and not something you could do in the pits, however there are some butane torch units that don't have an open flame that are intended to be used in a heat gun type of application.
Unread 09-12-2016, 09:41
AKA: Pinecone
One advantage of this method is that before the solder melts, you glue the wires into place. Sometimes in the heat of a quick moment (emergency repair in the pits etc) it's hard to hold two wire ends steady / champ wires down while soldering. This could be done safely by a very nervous person!
Unread 10-12-2016, 08:43
Back after 4 years off
FRC #5279
The wires should be joined together before you start soldering.
That is the root of my concern with these, everything I learned about soldering is that if you don't start with a good mechanical connection you will not get a good electrical connection. Even with the wires glued in place, there is not a solid mechanical connection.
I have no doubt that these will work fine in a lot of applications, but I don't see the advantage. For a fast/easy fix you won't beat a crimp with the right tool. For smaller gauge wire I would rather solder and then heat shrink it.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 10-12-2016, 10:42
ctt956 ctt956 is offline
Too many threads, too little time
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Probably. I have a two-setting Radio Shack iron that takes that long to heat up, and my dad has a Weller that's at least 20 years old, which takes equally long. I have used the Hakko digital irons, which heat almost instantly. I do have a Weller soldering gun that also heats fast.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 12-12-2016, 08:53
EVeryone,
The basic rule of a good soldering job is that both wires reach a temperature that will allow the solder to flow in between the strands of the wire.
These devices were developed for soldering a jumper wire to coaxial cable. The ring is meant to solder to the strands of the coax shield. In general, the shield uses very small stranding. These could be useful for emergency soldering of a broken wire but they are not fool proof. Do not trust them to have good mechanical strength. The two rings of non-metallic material are for water proofing. In use on coaxial cable, these would seal on one side to the outside jacket and the other side would be around the inner insulation surrounding the center conductor.
