Go to Post FRC: so inspiring, even car thieves can't handle it. - evanperryg [more]
Unread 08-12-2016, 13:50
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Re: drilling larger holes in aluminum
Originally Posted by dradel View Post
Personally I favor these for up to 3/4" they do come larger as well
https://www.amazon.com/gp/aw/d/B0082...ScL&ref=plSrch
Annular cutters are fabulous when a precise hole is needed. Our set has seen a lot of action since we bought it a few years back. Makes a great press fit bearing hole if done just right.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 08-12-2016, 14:14
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
We also use annular/Hougen/Blair cutters quite a bit. We have small hole (up to 3/4") and large hole (up to 1-1/2") sets. The only issue with them is the cutter is often very difficult to remove from the arbor after use. We use the little spacer/washer but often it is a a real struggle getting the cutter off. Maybe we are doing something wrong? Does anyone have any tips or tricks to making it easier?
Unread 08-12-2016, 14:30
Our set has a small flat on the top away from the cutting edge and we just use a set of channel locks or a wrench to break them loose. Very much important to wait for them to cool down before doing this as that makes it easier too and prevents burns from touching a hot cutter. We typically just grab the arbor in a vise and then break it loose so we can finish removal by hand.
Andrew Basse
Unread 08-12-2016, 16:18
MonroeM MonroeM is offline
FRC #3570
MonroeM is an unknown quantity at this point
We do a lot of modifying of old parts so it is somewhat often that we have to widen a hole on a mount of some kind. To do this we use a half horsepower dremel with an aluminum cutting bit on it. This when well waxed will cut through aluminum like butter.
Unread 08-12-2016, 17:06
James3245 James3245 is offline
FRC #3245 (Ravens)
James3245 is on a distinguished road
Thanks for all the tips and suggestions!
Unread 08-12-2016, 17:20
SparkyMark's Avatar
SparkyMark SparkyMark is offline
FRC #5801 (InSΠre)
SparkyMark is an unknown quantity at this point
Talking Re: drilling larger holes in aluminum
Y'all are making this way too hard. Get your hands on a set of GreenLee knockouts - a staple in electrical work. They come in various sizes, from 1/2" on up. Typically the larger sets will use a hydraulic puller, and they can cost a chunk of change, but we've used a smaller manual set for years.
Perfect for flange bearings - press fit or slide in with a tiny bit of cleanup. The only hole you have to drill is the 5/8" pilot for the 1/2" bit. If you want to go larger, use the 1/2" first then pick your desired size. Simple. Clean. Effective. Great for lightening holes too.
Safer than a hole saw and cooler than a step bit, they're a lot less messy and don't require lubrication. Properly cared for they should last forever.
(Zoro sells a slug splitter with four sizes for $140)
The actual sizes mentioned are "trade sizes" as these dies typically are used for conduit installation. The actual size is slightly larger (1/2" is .875 nominal, e.g.) and can be found via google. Sorry for the confusion.
Unread 08-12-2016, 18:04
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Put cutting fluid on the threads prior to putting the cutter on the arbor.
