Go to Post The magic is ALL in the mentors. - AdamHeard [more]
Unread 12-10-2016, 05:06 PM
WyattMarks WyattMarks is offline
FRC #4187
WyattMarks is an unknown quantity at this point
frc-toolchain package working on Debian Stretch
So, first of all you can't add-apt-repository by default on Debian, so you must install
software-properties-common
sudo apt-get install software-properties-common
Once you do that, you can do the normal
sudo apt-add-repository ppa:wpilib/toolchain
After you run this successfully, you must edit the sources file. So run
sudo nano /etc/apt/sources.list.d/wpilib-ubuntu-toolchain-zesty.list
(the file name might not be 'zesty' but it should be similar)
change any of the debian names from trusty or stretch or whatever it is to wily
then you must go to https://launchpad.net/ubuntu/xenial/...ibisl13/0.14-2 for 64 bit or https://launchpad.net/ubuntu/xenial/...ibisl13/0.14-2 for 32 bit
Download the .deb file and then run
sudo dpkg -i libisl13_0.14-2_amd64.deb
(or i386 for 32-bit) to install the library. This library is included with supported Ubuntu versions but isn't in Debian Stretch, so we can just install them from Ubuntu repositories
After this, run
sudo apt-get update
sudo apt-get install frc-toolchain
and then it should work!
Unread 12-10-2016, 05:08 PM
FRC #4187
Re: frc-toolchain package working on Debian Stretch
Okay, there are some typos.. how do I edit a post?
Unread 12-10-2016, 05:35 PM
As a new user you are probably restricted.
(As in many spam bots post then return later to add commercial links)
You'll need to request an edit by a moderator for this subforum.
See the bottom of C/C++ for a current list of subforum moderators.
Once you've been around awhile there will be an Edit button on your posts for 24 hours.
