Go to Post "A robot can always be fixed but a match can never be replayed." - Brian C [more]
Unread 12-10-2016, 01:52 PM
waffle_dynasty waffle_dynasty is offline
FRC #5010
waffle_dynasty is an unknown quantity at this point
5010 T-Shirt Robot Update
5010 has worked hard these past few weeks to get a working robot. Everything's pretty much come together except for a few nuts and bolts.
See a video here: https://youtu.be/NZGkK7Itcko
We've still got a few things to tinker with before we officially call it finished, but here are some specs:
  • 6 t-shirt rotating barrel
  • Car jack angle adjuster
  • 6 wheel pneumatic drive
  • SCUBA tank shooter
Unread 12-10-2016, 02:02 PM
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Re: 5010 T-Shirt Robot Update
Nice design! What material did you use for the actual barrels where the T-shirt was nested? What pressure do you use to shoot the shirts?
Looks good!
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 12-10-2016, 02:16 PM
FRC #5010
We are using PVC for the barrels and shooting at around 80 psi.
Unread 12-10-2016, 05:49 PM
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
What are you planning to use to rotate the barrel?Also how much space is there between the actual shooter and the barrel?
Unread 12-10-2016, 05:52 PM
Roboshant's Avatar
FRC #0226
Rookie Year: 2015
+ Concerns about the use of PVC
Originally Posted by artdutra04 View Post
Rule #1 when making air cannons is do not use PVC.
Rule #2 is DO NOT USE PVC.
There are huge safety concerns with PVC, because PVC IS NOT DESIGNED TO HOLD ANY KIND OF COMPRESSED GAS, AND HAS BEEN BANNED BY OSHA FOR USE WITH PRESSURIZED GAS IN INDUSTRY. PVC has the awful tendency to spontaneously explode when pressurized with any kind of gas, even if that pressure is below the maximum pressure stamped on the pipe. (The max pressure rating for PVC is ONLY for liquids, such as water).
On a personal note, one of my friends had a PVC air cannon explode while holding it a few weeks ago. He wasn't even moving, and the air cannon didn't hit anything. He was just standing there, holding the pressurized air cannon, when it spontaneously exploded between his arm and his body. He was very lucky in that the way the shrapnel flew out, nearly all of it missed him. His jacket on that side of his body was not so lucky, and literally was torn to shreds.
Since this air cannon is being shown as for "marketing", it seems like it would most likely be used at public appearances. In order to protect any innocent bystanders from possible exploding PVC shrapnel, I would seriously urge your team to avoid using PVC on the air cannon at all costs.
I don't want to sound negative here, but at the same time I don't want to see people put themselves in dangerous situations.
Unread 12-10-2016, 06:07 PM
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #0703 (Phoenix)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I share the concerns about PVC, though this particular design looks like it could easily led itself to the addition of a "Shrapnel Shield" around the barrels using polycarbonate or some other material.
That said, having a bunch of students sit with their faces inches away from an untested PVC barrel (WITH NO SAFETY GLASSES) was/is probably not the best of ideas.
Unread 12-10-2016, 07:38 PM
FRC #5010
We still have some sprockets to manufacture before we can motorize the rotator. There's only about 1/16" between the barrel and shooter.
Unread 12-10-2016, 07:45 PM
FRC #5010
The PVC barrels do not store any pressure. They are simply there's to help the t-shirts accelerate. When designing this robot, we knew the risks of PVC. The only pressure they have to support, I guess, is the back pressure from the t-shirt. This is way less than 80 psi and the team and mentors believe it to be safe.
Unread 12-10-2016, 08:55 PM
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
This ^^^
PVC is bad bad for storage but perfectly fine for use in a barrel.
Unread 12-10-2016, 09:12 PM
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
i'll be that guy: Where are the safety glasses?
Unread 12-10-2016, 09:17 PM
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
AKA: Dwight Howard
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is an unknown quantity at this point
Our team has a very similar design ( I wish I had a picture to post but I cant find one right now) Our has one solid aluminum barrel with a scuba tank shooter. We used acrylic as the main supports for the barrel and the top plate on the base. We also took RGB LED's and lined the inside of the frame to make the whole robot glow.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016), Student team Co-Leader, Documentation Chair (2017)
"It Doesn't Get Easier. You Just Get Better."
Unread 12-11-2016, 09:06 PM
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
Originally Posted by IndySam View Post
This ^^^
I'll second that. 343 has used pvc barrels on our t-shirt shooter for almost 10 years with no problems.
I didn't break it... this time.
