Go to Post Pompous boasts dont get you anywhere. Results get your name on the book... - Jeremy_Mc [more]
Unread 11-12-2016, 11:37
ABreyen's Avatar
ABreyen ABreyen is offline
Marketing Head and Team Management
FRC #2232 (Deus Ex Machina)
Team Role: Marketing
ABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of lightABreyen is a glorious beacon of light
Fancy RGBish lights on robot/cart/etc
Hey CD!
Just wondering, do teams have RGB-style strip lights on your robot/cart/elsewhere? (Strip lights like this) And if you do, how do you control it? Raspberry Pi or Arduino may be a good option for us, and it seems simple enough...
Also, is this legal? I'd assume so, so long as it does not communicate wirelessly during the match.
If you would, please let us know at http://www.strawpoll.me/embed_1/11851624! Thanks
Andrew Breyen
andrewbreyen.github.io
AHS FRC 2232
Marketing Team Head and Team Management
2232frc.github.io
Unread 11-12-2016, 13:32
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: Fancy RGBish lights on robot/cart/etc
We have used an Arduino with the FastLED library to control lights.
Unread 11-12-2016, 13:41
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
On our 2014 and 2015 robot, we had an arduino controlling the lights. In 2015 we completely redesigned our pit, working lots and lots of green LEDs that were the cheap, one-color ones. Those, we simply plug into an adapter which goes into an outlet.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Unread 11-12-2016, 15:43
davidaly46's Avatar
davidaly46 davidaly46 is offline
Electrical Engineering - UT Dallas
AKA: David Aly
FRC #0148 (Robowranglers)
davidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to beholddavidaly46 is a splendid one to behold
One color LED strips are the easiest to work with. Simple outlet adapters like stated above work well in pits, and if you plan on using them on the robot, you can always use the 5V rail on the PDB and a few resisters. In my opinion, when used for aesthetic and not operational purposes, single color strips that you can just set in minutes is the best way to go. I have seen too many teams run into code, power, and design time issues simply trying to do a little much with LEDs. Yes, it's entirely legal and pretty cool when used correctly.
Unread 11-12-2016, 16:36
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
On the robot, LEDs are legal as long as they conform to the other electronics rules. Last season, we used an Adafruit light strip connected to a Teensy LC (Arduino) communicating with the roboRIO over I2C. The LEDs would change color based on the alliance color, during autonomous, and when the robot took a shot.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 11-12-2016, 16:41
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Actually they are rgb leds that can flash and fade and all that, but I hid the remote so you guys couldn't mess with it.
Unread 11-12-2016, 18:19
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
My team used these LEDs on our 2015 robot. All the lights stay one color at a time. You can get a few basic effects, but we normally just kept them either red or blue each match. The inspectors were okay with it as long as the remote stayed in the pit, and you pretty much have to be standing next to the robot to change the colors anyway.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 11-12-2016, 18:50
Roboter
Rookie Year: 2015
They could change color, but the entire strip had to be one color at a given time, and we set it to green the whole time because that is one of our team colors.
Unread 11-12-2016, 22:58
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
We have not used any programmable/addressable LED strips on our robots, though we have used them on mascots and other projects. If you do want to use addressable LEDs on the robot, I absolutely recommend a secondary processor so that the roboRIO is not spending time switching individual LEDs. Barring a significant change in the controls rules, LED controls CAN be outsourced to an external processor; the rules have been written to require that signals to actuators come from the roboRIO; lighting, sensors, and computing/processing have traditionally been available for offloading to a coprocessor.
Unread 12-12-2016, 15:11
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
We were going to use these IKEA DIODER LEDs for underglow lighting on our chassis. There's a little dial to select the color (not a remote control) and we would have powered it off a VRM or PCM relay control. We were going to dial in either red or blue for our alliance, or purple (our team color).
Unfortunately we just didn't have enough time to install it.
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
Unread 12-12-2016, 16:08
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If you intend to put these on your cart, please make sure you can easily turn them off. I've repeatedly had to ask other teams to turn off their blinking lights when we are in que desperately trying to fix something and they are shining in our eyes.
Think very hard about how to make them look cool but NOT be obnoxious. Every team around thank you for it.
