Go to Post We are reluctant to deprive you of the experience of learning how to do your own research. - Alan Anderson [more]
Unread 10-12-2016, 21:24
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Automation Direct Solenoid Cables
Hey guys,
I was looking to purchase this solenoid for my team from Automation Direct. However, I am unclear as to whether or not they come with the 11mm DIN cables. If they don't, is there somewhere I can get them other than AD? They seem to be out of stock at the moment, and I would like to have some on hand for the season.
Thanks so much!
Unread 10-12-2016, 21:32
ctt956 ctt956 is online now
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
Re: Automation Direct Solenoid Cables
Judging by the "What's in the box" picture and the cables' appearance on the "Recommended Items" list, I would say no to their inclusion. Not sure where else to get them.
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 10-12-2016, 21:36
FRC #5202
Yeah, I was assuming that from that. I should have been more clear in the OP, this thread from a year ago seems to indicate that they do, which is why I wanted confirmation.
Looking back on it, it seems that I misread it.
As a followup, does anyone know if I can just plug these connectors directly into the solenoid, as opposed to using the female cables?
EDIT: Looked into it a bit. Data sheets are there for a reason!
It looks like the only difference is the direction that the wires run. The connectors should work for both. Thanks all!
Unread 11-12-2016, 00:06
jasonpatel555 jasonpatel555 is offline
AKA: Jason Patel
FRC #2200 (MMRambotics)
jasonpatel555 is on a distinguished road
The "whats in the box" picture shows the 2 connectors screwed on top of the solenoid pins. They're the dark grey things on top with the little screw. You'll just need the wire. The advantage to the ready made connectors, with the wire, you can buy on the site is that they are a little bit better built and they include an indicator led on top of the connector housing. The ones in the box are cheap and flimsy, but they are probably good enough for FRC. The LED is also very handy for diagnosing problems.
The best source for info on anything from Automation direct is to call them. They have awesome support and always get back to me very quickly if I can't speak to someone right away. It's the reason I buy as much stuff from them whenever I can at work.
Unread 11-12-2016, 09:56
chapman1's Avatar
chapman1 chapman1 is offline
FRC #3688 (Suttons Bay Norsemen Robotics)
chapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond reputechapman1 has a reputation beyond repute
You do not need to buy anything else besides the solenoids. The accessory cables are quite big and clunky anyway - good for industrial applications but not suitable for robots.
Older, but still somewhat coherent.
Unread 11-12-2016, 13:01
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
Sounds like this has been answered already, but if you need further assistance with any AutomationDirect parts, please let me know.
Unread 11-12-2016, 13:59
FRC #5202
Originally Posted by jasonpatel555 View Post
The "whats in the box" picture shows the 2 connectors screwed on top of the solenoid pins. They're the dark grey things on top with the little screw. You'll just need the wire. .
Does this mean I just solder it to the connector? To that end, is there a diagram showing which pins to solder to? I read that we only need to use the two black wires on the accessory cables to use it with the PCM, and I would like to know which pins these correspond to on the connector.
Unread 11-12-2016, 14:46
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
We use the AVS-52xx units, and have used the AVS-32xx units in the past. Same connector.
There is a screw that holds the connector shell on, just remove it, lace through the wires, and screw them down into place using a regular screwdriver, and put the connector shell on. It is simple. You don't need to buy the cables for FRC because it will save you weight and money.
It's super easy. Buy one and try it out.
Ed Barker
Unread 11-12-2016, 14:56
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
I just wish all of you would stop calling them "solenoids".
They're valves. Solenoid valves.
The solenoid is the little magnet inside that shifts it. But it is first and foremost a valve.
If you wanted a blue car, you wouldn't say "where do I buy a "blue"?"
Unread 11-12-2016, 15:46
chapman1's Avatar
Wink Re: Automation Direct Solenoid Cables
In the event you are a grammar cop as well: Your correct. ;-)
Unread 11-12-2016, 20:12
FRC #5202
Sorry, don't mean to prod you. Did you leave the ground pins disconnected? I'm looking at the data sheet and there's pins 1, 2, and GND on each side of the solenoid. From the product insert, 1 and 2 are marked as DC+ and DC- respectively. Since these are DC solenoids, is there any danger in leaving GND unhooked?
EDIT: Here's a photo of said insert.
Unread 11-12-2016, 20:46
ebarker's Avatar
AKA: Ed Barker
Just wire pins 1 and 2, and you are all done.
It's that easy !
Ed Barker
Unread 11-12-2016, 20:51
FRC #5202
It's that easy !
Thank you!
Unread 12-12-2016, 13:06
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is online now
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen will become famous soon enoughWren Hensgen will become famous soon enough
Originally Posted by ollien View Post
Hey guys,
Hey! Just making sure that you're aware this is a 3/2 valve, not a 5/2. It will actuate either half a cylinder (Spring retract, spring extend, or gravity return) or an air motor, but it won't work with a standard double acting cylinder.
Unread 12-12-2016, 13:41
FRC #5202
Yep! I realized this soon after I posted the thread. Realisitcally going to end up purchasing this one.
Thanks for the heads up
