Go to Post It's about picking a good alliance, not good robots. - evanperryg [more]
Unread 12-12-2016, 15:56
Wren Hensgen's Avatar
Wren Hensgen Wren Hensgen is online now
Alum, Mentor, Volunteer
AKA: Wren Hensgen
FTC #10353 (MetalWorks)
Wren Hensgen will become famous soon enoughWren Hensgen will become famous soon enough
Re: Automation Direct Solenoid Cables
Originally Posted by ollien View Post
Yep! I realized this soon after I posted the thread. Realisitcally going to end up purchasing this one.
Thanks for the heads up
Good choice. These are actually Bimba/Mead valves, rebranded by Automation Direct.
Any reason for a dual acting over a spring return?
Unread 13-12-2016, 07:56
rfolea's Avatar
rfolea rfolea is offline
AKA: Rick Folea
no team (Forsyth Alliance)
rfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant futurerfolea has a brilliant future
I'm surprised no one mentioned this as an option (see photo). remove both the shroud and the header and just connect directly to the pins using crimp lugs ...
The only disadvantage is you loose the built-in diagnostic LED ...
Again, you only need two pins...
Unread 13-12-2016, 08:06
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
In theory? Simply the amount of control one gives us over the other. Spring return is by no means a bad thing, but I'm in the camp of thinking that it's best to keep the state of the solenoid after disabling, for safety if for nothing else.
In reality, it depends on the application. If it turns out it might be better to use spring return, we can always pick some up. I figure it makes more sense to buy ones that are a bit more versatile.
Unread 13-12-2016, 08:16
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
Originally Posted by chapman1 View Post
Your correct. ;-)
You're right!
Unread 13-12-2016, 10:26
AKA: Wren Hensgen
The other disadvantage in this is that you now have two convenient connections (which are fairly easily bent) right next to each other. A bad bump, or some dropped metal shavings, and they short out.
Best practice is to protect your solenoids in some way, I've seen way too many teams mount them out on their arms.
