#18
Re: Automation Direct Solenoid Cables
I'm surprised no one mentioned this as an option (see photo). remove both the shroud and the header and just connect directly to the pins using crimp lugs ...
The only disadvantage is you loose the built-in diagnostic LED ... Again, you only need two pins... |
