Go to Post Beware of the following: boredom intelligence = ??? <- could be anything... - JBotAlan [more]
Unread 13-12-2016, 08:34
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Fast spiral tap speeds
I've used the hand taps for years: lots of oil, take your time, put oil in the hole as you cut the threads, back the tap out to clear the tool after a few turns, remember to use oil, don't force the tap it will cut the threads and of course, oil is your friend.
Very successful on all the taps I've done. And with all the roboteers I've taught to tap holes.
I need to tap four 5/16" holes in 2" steel pipe (clearly not a robot project) and a friend gave me "fast spiral tap". These look like twist drills, but have the tap threads on the first 1/2 of the bit. So I drill my starter hole and then use the fast spiral tap to do the tap.
I'm looking for the speed I should set the drill to. In this current project, I'd love to be able to use a hand drill rather than trying to move the project to the shop and the drill press, so if you have hand drill tips that would be great.
I'm also good with "Hey, since you can use a hand tap, use that, just remember to use oil, it's only 4 holes."
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-12-2016, 13:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Fast spiral tap speeds
It's going to be really hard to align that straight enough with a hand drill. I don't ever tap by hand with spiral flute taps because of that reason.
I would go as slow as possible until you know you're aligned and then you could bump it up to a couple hundred rpm
2001-2004: Team 100
2006-Present: Team 254
Unread 13-12-2016, 13:18
JR0405's Avatar
JR0405 JR0405 is offline
#StaySavage
AKA: Jack Ross
FRC #5822 (Wolfbyte)
Team Role: Driver
JR0405 has a spectacular aura aboutJR0405 has a spectacular aura aboutJR0405 has a spectacular aura about
I remembering seeing a guy on YouTube use a block of wood with a hole drilled in it to make sure he started straight. I'd recommend doing this.
Unread 13-12-2016, 13:30
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
V-Tap guides are helpful for starting perpendicular taps:
https://www.amazon.com/V-Tap-Guide-S.../dp/B000ZN30U4
Unread 13-12-2016, 14:13
Ok, so I'll drill and just use my hand taps since I know that works.
Thanks to the others that posted, I agree that I've "over thunk" an easy job.
Unread 13-12-2016, 15:10
Cory's Avatar
AKA: Cory McBride
If you are looking to be able to tap through holes without stopping and reversing the tap to break off the chip, look into spiral point taps. They will drive the chip ahead of the tap and should tap any reasonably ductile material in one shot without reversing. They are also no harder to align than a standard hand tap.
2001-2004: Team 100
Unread 14-12-2016, 21:39
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Seconded. At my employer, this is they type that engineers (like myself,), fabricators, and maintenance workers use. They're great for both hand use and machine use (I've used them at "slow" speeds using cordless drill, drill press, and lathe with good results).
As for brands (at least the ones I've used), Hertel ones aren't too bad (I've grenaded a few but I was abusing them a bit) and the few Kennametal ones I've used at work were awesome (same abuse as the Hertels, didn't break). Irwin ones are pretty good as "retail" brands go (their tap handles not so much, the one I bought my father in law cracked on the first use). Craftsman ones are good as well. Harbor Freight ones (never used at work, personal work only) aren't so good but for aluminum and mild (unwelded) steel are OK if you're nice to them. Avoid the cheapest ones though, as they might as well be made of silly putty. The mid-grade and upper tier ones are worth the extra money.
Somewhat relevant trick of mine: if there is trouble clamping the part in the drill press vice, the tap is slipping in the drill chuck, or if you're tapping a blind hole, use a drill press/lathe to start the tap (to make sure it's straight), and once the tap has started, back out the tap and move the part to the bench vice and finish it by hand. I had a weird foot for a jig clamp I was fabricating for a work project last week that drilled fine on the drill press but wasn't agreeing with the tap (deep hole, M8 tap, Jacobs chuck was slipping) and this trick was how I salvaged the part.
TL,DR: Spiral point taps are awesome!
Unread 17-12-2016, 16:36
DonRotolo's Avatar
Back to humble
FRC #0832
Although the OP decided to solve the problem by using a different tool, the spiral point tap he was given appears to be the same as what Cory mentions.
Regardless of the RPM, it is critical that he have a way of reversing (or at least stopping) the tap before the tip hits anything solid. So if he doesn't have a Tapmatic head, slow is the answer. But a good tap can run at several hundred RPM, maybe 1200, depending on the details (a harder job needs slower speeds)
Tapping with a hand drill will break the tap with even the slightest movement. Don't even try.
Unread 17-12-2016, 17:48
They look more like a spiral drill bit with a tap at the middle rather than what Cory posted. Best picture I could find was this one
I found a site that had the speed calculations I was really after
For mild steel pipe and the 1/4" size hole/tap I needed to go ~30 RPM.
After I did the project with a hand tap, I did try the drill/tap just as a learning point for me. In a press, it was easy peasey to drill the hole and then tap right behind it at a slow speed. Needing to be able to reverse is a key thing.
Unlikely I would have been successful out in the yard doing this with a hand drill.
And if I could afford a Tapmatic head at $350, I'd be lots smarter than I am and would have done this before I sank the pipe into 350lbs of concrete.
Thanks again to all that replied.
Unread 17-12-2016, 19:14
Cory's Avatar
AKA: Cory McBride
Oh, that's just an integrated drill/tap. Totally different than what I thought you had.
I thought you had one of these:
The one you have should in theory not present any problem with following the hole since it's also making the hole (though it could easily end up with both being non-perpendicular to the surface). The one above is much more difficult to align perpendicular to the hole since it has almost no lead in and the flutes are more "aggressive" than a standard hand tap.
2001-2004: Team 100
