Go to Post Remember, never underestimate the determination of thousands of FIRST students! - Jay H 237 [more]
Unread 13-12-2016, 16:25
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Getting started with Java for FRC
Hello everyone !
We are a second year team with very limited programming experience.
Our FTC team switched to Java this fall and it was a very successful move. We are planning on doing the same with our FRC team since we are building the skills and want to keep up with it.
Setup up Android Studio was ok, but not easy. We were fortunate enough ot find some good documentation and people to help wiht the FTC SDK and gettitng everything setup properly.
Is there such a thing for FRC? I would like to find somewhat of a check list to make sure that everything on laptop is setup properly... eclipse, jave sre and other....
If you know of good site or documentaiton, please post.
Thanks in advance
Unread 13-12-2016, 16:28
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Re: Getting started with Java for FRC
Here's the official documentation from WPILib:
https://wpilib.screenstepslive.com/s/4485
Unread 13-12-2016, 17:09
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
And after you are setup, checkout https://wpilib.screenstepslive.com/s/4485/m/26402 It will walk you through using robotbuilder and get you started, with well structured code.
Unread 13-12-2016, 19:21
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Here's the full javadoc (API reference) for wpilib: http://first.wpi.edu/FRC/roborio/release/docs/java/
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 19-12-2016, 22:21
BenBernard BenBernard is offline
FRC #5687 (The Outliers)
Rookie Year: 2015
BenBernard is on a distinguished road
Our team switched from Eclipse to IntelliJ last season, and I personally would never want to go back.
I put together a "getting started" page for our new programmers, with links to all the tools we use and pretty detailed instructions. It comes with no warranties, but you are welcome to use it. Our github site also includes our Recycle Rush and Stronghold code as well as some off-season projects.
Unread 20-12-2016, 09:57
Jayd009's Avatar
Jayd009 Jayd009 is offline
AKA: Jonathan
FRC #4468 (Fernbank LINKS)
Rookie Year: 2016
Jayd009 is on a distinguished road
I did a presentation this Fall on the basics of FRC Java Programming. You can view the recording, powerpoint file, and all of the example code at http://www.fernbanklinks.com/first-c...ction-to-java/. My team also stored our robot code from last year at https://github.com/FernbankLINKSRobotics/GRITS16.
2016: District Event Winner @ Columbus District Qualifier (PCH)
2016: Engineering Inspiration Award @ Peachtree District State Championship
2016: Tesla Subdivision Playoffs Appearance @ FIRST Championship
Unread 20-12-2016, 10:34
Coach Seb's Avatar
Rookie Year: 2015
Can Robotbuilder still be used with IntelliJ?
What are the main advantages of InteliJ vs Eclipse?
I am almost starting from scratch here.. very little java experience, but i am relying on Robotbuilder and the WPI documentation to get started... can IntelliJ support that?
Unread 20-12-2016, 11:29
Programming Mentor
RobotBuilder is a completely separate program. You can create a shortcut, run it from the command line, etc. You just have to install WPILib and you have it. It is not linked to Eclipse, the WPILib plugin for Eclipse, includes a handy shortcut for RobotBuilder. Using IntelliJ you can do the same.
This is a more personal question. If you are happy with Eclipse, I would not bother. Personally IntelliJ has better VIM bindings (I am an old guy with old finger memory), and a nice presentation mode for displaying code on a projector; however, both are pretty impressive.
Given that, if I were you I would use Eclipse this year, if over the summer you want to play with IntelliJ, make sure it works for you etc. Go for it, but why add one more moving part when you are still trying to find your footing?
Unread 20-12-2016, 12:22
Coach Seb's Avatar
Rookie Year: 2015
thank you ! ill stay with eclipse to eliminate any confusion this year...
