Go to Post You enjoy your pepperoni pizza, I'll enjoy my cheese and peppers, and we can both agree that people that like pineapple on their pizza, while strange... are completely entitled to their opinions. - Andrew Schreiber [more]
Unread 13-12-2016, 21:13
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: [FRC Blog] FIRST Choice 2017
Originally Posted by maxnz View Post
FIRST Choice is giving me this:
{"Message":"The given key was not present in the dictionary."}
Any idea why?
I'm running into the same issue. I logged in successfully yesterday, and now am running into the same error.
Unread 13-12-2016, 21:43
cpapplefamily cpapplefamily is offline
FRC #3244 (Granite City Gearheads)
Rookie Year: 2015
cpapplefamily has a spectacular aura aboutcpapplefamily has a spectacular aura about
I googled first choice andymark and used this link. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&u act=8&ved=0ahUKEwjdiZTW1PLQAhWMWBoKHV2aCRsQjBAIIjA B&url=https%3A%2F%2Ffirstchoicebyandymark.com%2Flo gin&usg=AFQjCNHZebxmPoKlOb7IXDmozE8iRMH8sA
or
https://firstchoicebyandymark.com/login
and got in.
Unread 13-12-2016, 21:52
Sold out of several more products now that open ordering began.
NeveRest 60 (fc17-020)
PG71 Gearmotor With Encoder (fc17-017)
Sensor6PAK (fc17-023)
the purple hex shaft collars
etc.
Unread 13-12-2016, 21:53
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
Neither of those are working for me.
EDIT: I went here: http://firstchoicebyandymark.com/everything/ and I'm able to access the site.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
Unread 13-12-2016, 21:58
I get the message when I do certain things, like try to login, but if logged in I can navigate around.
Unread 14-12-2016, 20:11
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
Let me first start by saying that my team is very happy with the results and with the process for FIRST Choice this year.
Ok, now that that's out of the way let's do some analysis:
Too cheap:
Also known as "what sold out?" or "what should have been worth more points?"
In no particular order
500EX Hex Hub (fc17-013)
AMT103 Cable Assembly, 5-pin, 5 x 22AWG, 1 ft. (fc17-030)
AMT103 Cable Assembly, 5-pin, 5 x 22AWG, 6 ft. (fc17-031)
Pneumatic Solenoid, Double Valve Kit 2016 (fc17-041)
CIM Motor (fc17-069)
Talon SRX (fc17-070)
Victor SP (fc17-071)
NavX-Micro sensor (fc17-074)
CAN Wire, 22 AWG, Green/Yellow twisted pair, 4 ft. long (fc17-081)
1/2" Hex Shaft Collar, Blue (fc17-082)
1/2" Hex Shaft Collar, Gold (fc17-083)
1/2" Hex Shaft Collar, Green (fc17-084)
1/2" Hex Shaft Collar, Orange (fc17-085)
1/2" Hex Shaft Collar, Red (fc17-087)
Denso window motor connector 2 housings & 4 terminals (fc17-150)
DryLinŽ W, linear guide system, guide carriage, assembled (fc17-151)
Precision Metalworking Gauge Kit (fc17-156)
Acer Aspire E11 Netbook (fc17-158)
Too expensive:
Less than 4% of available items claimed; aka maybe the price was too high
Ordered by smallest fraction sold of inventory gone
Single Edge Steel Track, Size 3, Variable Length 16-26" (fc17-148)
Single Edge Steel Track, Size 1, Variable Length 16-26" (fc17-146)
Mounting bracket (fc17-142)
USB A Male to B Male, 2m, Grey(fc17-024)
iglide plastic clip bearing (fc17-059)
Fan, small, 20mm 412 (fc17-039)
Industrial RJ45 Modular Plug (fc17-001)
iglide plastic thrust washer (fc17-062)
Lead Screw (fc17-139)
Compact Fan, 12V, 10mm 412F (fc17-040)
iglide plastic flange bearing (fc17-060)
8 x 3-conductor Lever nuts (fc17-134)
iglide plastic sleeve bearing (fc17-061)
AndyMark Anchor Bolt (fc17-015)
MC5e Catagory 5e Modular Patch Cord, (colors & lengths vary) (fc17-154)
47mm OD, 17mm ID Bearings (Sleeve of 10) (fc17-126)
igubal spherical rod end bearing EBRI-10R (fc17-065)
iglidur Tribo-Filament (fc17-056)
Fan, large 4412 ML (fc17-038)
26mm OD, 10mm ID Bearings (Sleeve of 8) (fc17-127)
Teflon tape PTFE-1/4 (fc17-055)
Unnecessary limits:
There was a per-team limit but less than 25% of available stock was used
Ordered by fraction of stock remaining
Digital Multimeter Model 175 (fc17-136)
LaunchPad Evaluation Kit (fc17-131)
HS-322HD Servo (fc17-053)
iglideŽ PRT slewing ring (fc17-063)
Robot Signal Light (i.e. Panel Signal Device) (fc17-145)
