Re: Andymark 1.1 Compressor Data
Which model of Thomas compressor are you referring to when saying this?
Good job on the data collection.
One minor upgrade to your testing setup would be to only switch valves and not air tubes and have a separate compressor/battery charge the system to 80 psi. I mention this as minor as the data seems fairly consistent. My next question is the power needed worth the speedier air fill? This might be hard to answer for an unknown situation. So, how about the efficiency of each unit? Another useful measure might be amp-hrs needed to fill a tank. The AM1.1 has a max draw of 16 amps The Viair 90c has a max draw of 11 amps (from the AM site) Dave |
Just curious...why 80-120?
My guess is, that is the approximate range the pressure sensor switch swings the pressure during a normal match.
Again, that's my guess. Let's see what the OP says was their reasoning. |
80-120 was to simulate the pressure that would be mainly relevant during a match
IMO it would be better to test the 60-100 range to see how long it takes for your robot to recover between actions. |
#7
Out of curiosity what compressor did you use last year, and how often were you actuating cylinders? |
#8
It is possible that the test being centered on 100psi is based on my post in the other AM1.1 thread. Does anyone have any good gouge on the duty cycle of the Thompson compressor referenced above? None of the web pages or data sheets listed it. Unless by "continuous" in some labels they mean 100%? If so, the Thompson would outperform the 1.1 in a demo/practice mode, and in many cases in competition mode. That would also explain the much higher price. |
#10
What do you mean "usually set the switch"? Are we allowed to use adjustable pressure switches again? I remember being part of a lively discussion a couple of years ago where the Chief Robot Inspector took us down a rule interpretation that I didn't anticipate. The rules got more specific after that point, including R78c from last year. |
#11
We still use the adjustable switches during practice and for demos, which use a lot more air (over the course of hours) than the competition robots. Use of the preset 115s during competition is offset (or more than offset) by doing fewer cycles per hour.
#12
Its motor's rating is ~75 Watts, so it can draw 75/12 = 6.3 Ampere continuously. This is significantly less than the power consumed when the compressor is running -- then it draws about 11 Ampere, so it is consuming 132 Watts. Some of the power consumed actually compresses air, and the rest is lost as heat in the motor coils, or as friction in the pump, or in other ways. If the compressor's continuous rating is limited by the size of the motor, then its duty will be about (6.3/11)^2 = 33%.* However, most compressors of this type are limited by the size of the pump; experience with this compressor in FRC application suggests its duty limit is less than 33%. ------------- *Motor heating is roughly proportional to the square of current draw, because most of the heat comes from resistive losses in the coils. |
#14
Good enough for me. I'll take lower current and faster fillups any day of the week. Unless this is significantly slower at 60 PSI and the others are not, this seems better for our application than the viair which isn't great at topping off tanks.
#15
I will also try to get data on amp hours at the 80-120 psi mark and filling up tanks from 0psi. |
