Go to Post There is one unbreakable and unwritten law in FIRST, don't make it hard for your alliance partners to play. - Al Skierkiewicz [more]
Old 12-14-2016, 05:30 PM
D.Allred's Avatar
D.Allred D.Allred is offline
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Re: New AndyMark Product Game Hint???
Originally Posted by SenorZ View Post
Does $6 for a 2" wheel seem a bit steep to anyone else?
[EDIT: just saw how expensive the tear drop flex rollers are!!!]
Seen similar wheels on many 2015 robots for landfill tote gathering.
Not really. What's your alternative for this application?
I've seen team use something similar to the 4" flex wheel from McMaster (2497K12 for example). Those are $30+.
Another alternative was making your own roller from polyurethane tubing - which isn't cheap either.
David
Old 12-14-2016, 05:31 PM
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
Looks like these would be fairly easy to modify by cutting the ring out and getting 6 point star.
True, but then they wouldn't be COTS. So they take manufacturing time and replacements, which will probably be necessary as they take a beating spinning at high speeds, will count against withholding. Also just the extra effort. Comparatively, I would rather pay an extra dollar or two per wheel/star to get a COTS 0.5" hex star than have to modify it. That's just me coming from a small team with limited manpower and manufacturing capabilities; I imagine for larger teams like 973 that is not a problem.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Old 12-14-2016, 05:40 PM
BumblingBuilder's Avatar
BumblingBuilder BumblingBuilder is offline
Red is fast
AKA: Matthew
FRC #2169 (KING TeC)
BumblingBuilder will become famous soon enough
A good "on a budget" alternative to these holed wheels is always the banebot wheel (orange or bue ideally, which are -/+ 5A of these wheels respectively). They worked well in 2015, so I can't imagine them not working well if we're getting rigid game pieces next year
2014: FRC 2169 scouting/spirit, FTC 7897 Mechanical
2015: FRC 2169 Mechanical/CAD
2016: FRC 2169 Mechanical/CAD
2017: FRC 2169 Head of Mechanical
Old 12-14-2016, 05:57 PM
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Could just be me never having used the material but .425" seem like it would be fairly extreme for an interference fit.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Old 12-14-2016, 06:00 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I noticed that as well, but I'm assuming the AndyMark team found it was easy enough to use.
Old 12-14-2016, 06:11 PM
Bob Steele's Avatar
On the RIBMEATS bandwagon....
AKA: Bob Steele
Yes and no, they do appear to be waterjet out of sheet... and the material isn't that cheap. For low qty production the price seems about right.
[QOUTE]I never understood why they were made with a 0.5" square bore instead of hex. I imagine (with absolutely no real-world testing of course) these new wheels won't work as well as the entrapption stars for intakes of spheres, like the boulders this year because the stars can get more than tangential contact. I would love to see AndyMark come with with a v2 of the stars with a 0.5" hex bore just for ease of use.
We used modified entrapption stars that had hex bores to collect the frisbees from the floor in Ultimate Ascent... they worked quite well. We had a friend from Indianapolis make them for us. (Mike Trapp actually) He is a great guy by the way!! An unsung supporter of FIRST and STEM education.
Oblarg Oblarg is offline
AKA: Eli Barnett
This is arguably consistent with the ball-nonball gamepiece trend, if it is at all indicative of "rigid objects" being game pieces.
"The breakfast of champions!"
Old 12-14-2016, 06:12 PM
AdamHeard's Avatar
Lead Mentor
Balls can be rigid.
Old 12-14-2016, 06:13 PM
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Maybe 0.425" fits tightly on a Churro? If so, then it is even tighter on hex shaft stock.
Richard Wallace
since 2003
Old 12-14-2016, 06:19 PM
AKA: Eli Barnett
Balls can be rigid.
Most balls are not, though, thus my inclusion of the word "arguably"
Old 12-14-2016, 06:22 PM
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
The word "conveyor" seems to stir up something in my mind... Maybe those fragmented pieces of conveyor belts hidden all over the images they released in the DLC packs?
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Old 12-14-2016, 06:25 PM
This is what makes Chief Delphi great! Argumentation FTW.
Seriously, any particular game is not played with most balls. We'll get the selected balls, or none.
However, if we do get balls and they are rigid, then I really hope they are also very light.
Richard Wallace
since 2003
Old 12-14-2016, 06:44 PM
mr.roboto2826's Avatar
mr.roboto2826 mr.roboto2826 is offline
AKA: Niklas Olsen
FRC #0148 (Robowranglers)
mr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nicemr.roboto2826 is just really nice
.425" Seems about right for a "rubber esque" material. 2826 has used a material called linatex in the past which looks almost identical to what is pictured. We often had .125" to .25" of under sizing on our interference fit. I'm sure Andymark can enlighten me as to the actual material, but I', sure they tested if thoroughly.
First Updates Now Shows Producer.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
Old 12-14-2016, 06:54 PM
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Originally Posted by Cothron Theiss View Post
Ooh, this looks really nice. These wheels would be super helpful for intaking rigid game pieces. At first glace, I was concerned about the hex shaft turning inside of the hex, but .425 is a hilariously heavy interference fit. I do wonder if using Thunderhex with these wheels would pose any issues. I doubt it, but I can't really say for sure.
Emphasis mine.
We actually cut a bunch of samples over the summer in .025" increments to test this size, and found that .425" flat-to-flat is the right number for this specific profile and material combination. This number would change for a harder or thicker material, as well as a part with less holes in it.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Old 12-14-2016, 06:57 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Balls can be rigid.
The Nerf Howler is actually quite rigid!
Throw one and see if you hear a Steam Train Whistle!
