Go to Post 10:50PM, 1/14/16: I predict that hot dog wheels will grace Einstein before Mecanum wheels will. You heard it here first. - CalTran [more]
Unread 15-12-2016, 14:55
jimfl014 jimfl014 is offline
FRC #5000 (HammerHeads)
jimfl014 is an unknown quantity at this point
Java compile error
We are moving to Java this year from Labview. Using last year's robot we are trying to code it using Java. On two separate laptops we get the same error when trying to run: PCs are both 64 bit running Windows 10
Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Users\HammerHeads\AppData\Local\Temp\libwpilibJ avaJNI8681530594205079588.so: Can't load this .dll (machine code=0x34) on a AMD 64-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.load0(Unknown Source)
at java.lang.System.load(Unknown Source)
at edu.wpi.first.wpilibj.hal.JNIWrapper.<clinit>(JNIW rapper.java:47)
at edu.wpi.first.wpilibj.RobotBase.initializeHardware Configuration(RobotBase.java:170)
at edu.wpi.first.wpilibj.RobotBase.main(RobotBase.jav a:182)
Unread 15-12-2016, 14:58
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Java compile error
This is for simulation mode? I don't believe it runs on Windows yet. If you meant to deploy to the robot instead of simulate, right click the project > Run As > WPILib Java Deploy
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 15-12-2016, 14:59
Volunteer, WPILib Contributor
no team (Waiting for 2021)
That looks like you are trying to run the code on your development computer. That doesn't work, and is not currently supported. Follow the instructions at the link below on how to properly get the program to deploy to your robot.
http://wpilib.screenstepslive.com/s/...to-the-roborio
Team 4488 - Mentor 2013-2016
Unread 15-12-2016, 15:04
It sounds like your saying that the laptop has to be connected to the RIO, it's not. I was thinking that I could just use the run as a way to make sure the code compiles properly and I would just get an error that it could not contact the robot.
Unread 15-12-2016, 15:07
If you use the deploy function in the link above, or as Erik posted, that will build for the RoboRIO, and then fail if it can't connect. Trying to just run it on the desktop will compile as well, and then that error is showing when it is trying to run the code, and then failing because it's not running on a RoboRIO. So if you do get to that error message, the code will have compiled correctly, but its better to just do the deploy, and then let that fail to connect.
Unread 15-12-2016, 16:19
Thanks for clearing that up and responding so quickly!
Look forward to getting to the build site and running it on the real thing
