Go to Post I know alot of the rookie teams were helped out alot this year. Do the same thing for the rookie Volunteers as well. - wilsonmw04 [more]
Unread 15-12-2016, 15:14
phurley67 phurley67 is offline
Programming Mentor
phurley67 is an unknown quantity at this point
Roborio and Real Time Clock
So from our RoboRIO image in /etc/init.d/bootmisc.sh
I see this little nugget:
# Set the system clock from hardware clock
# If the timestamp is more recent than the current time,
# use the timestamp instead.
test -x /etc/init.d/hwclock.sh && /etc/init.d/hwclock.sh start
I don't have a /etc/init.d/hwclock.sh, but I wish I did :-). It would be nice if our log files had real date/time stamps if for no other reason than to keep things organized. Is anyone currently using RTC? Also double checking that the RIO does not have one and I just need to go buy a battery or something :-)
Unread 15-12-2016, 15:19
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Re: Roborio and Real Time Clock
I am not sure, ssh to the roboRio and type 'date'. If it is working the system clock is present. The relative timer in the kernel is required and sometimes, in embedded Linux systems, a virtual RTC is created using the jiffy clock to progress the time.
Unread 15-12-2016, 15:29
The roboRIO does not have a battery powered RTC. However, the DS sends the time when it connects, which the roboRIO uses to set the system time. If you wait until the DS connects, you can have correct timestamps, without a RTC.
Unread 15-12-2016, 18:37
Programming Mentor
Ahh that make sense. I have been doing all my testing with QDriverStation, which apparently does not do the time update (at least not from my Mac :-). But I remember seeing fairly accurate time data in the past -- it was actually driving me nuts.
Thanks
Unread 15-12-2016, 22:28
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Originally Posted by Joe Ross View Post
the DS sends the time when it connects, which the roboRIO uses to set the system time..
Can confirm. Had some weird timestamps on logs last year, took us waaaay too long to figure out what was going on.
