Go to Post you might want to consider the Edu-Robo-Whatevertheheckitscalled RC - Matt Krass [more]
Unread 16-12-2016, 07:54
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: pic: 4143 differential swerve concept
Mechanically elegant - essentially just two nano style gearboxes and an idle thrust bearing.
However, presuming two drive trains and rotation is obtained by spinning the wheels at different speeds, you would probably need three encoders per module. One would be for each wheel and a third to measure rotation, as rotation is likely to drift considerably from the difference in rotation of the wheels.
