Go to Post Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom :P - Chris is me [more]
  #31   Spotlight this post!
Unread 06-12-2016, 23:44
dardeshna's Avatar
dardeshna dardeshna is offline
Build Captain
AKA: Devin Ardeshna
FRC #0008 (Paly Robotics | Team 8)
Rookie Year: 2015
dardeshna is an unknown quantity at this point
Re: Exhaust in Solenoids
Originally Posted by FTC Team CC View Post
Here is a diagram I drew of our setup for the solenoids
It might not be a great drawing, but I hope it helps you understand our setup a little bit better
http://imgur.com/a/g2MT4
Team 8 literally had this issue earlier today with the same manifold solenoid setup. While bridging A ports and B ports to plug them is probably also contributing to your issue, the way we resolved the original problem you described was actually quite simple.
Try unplugging all of the tubes from the manifold, unscrewing the solenoids, removing the rubber gaskets, and blowing out the internals of the solenoids and manifold with compressed air. Then reassemble carefully. And while you are at it, plug the unused ports properly with the loop setup someone posted a picture of above. For us, it was likely something was either loose or improperly installed.
You could think of this as the good old reboot! Good luck
Originally Posted by PVCMike View Post
You can make your own plugs for the push fittings in a pinch, super easy. Cut a 2" piece of tubing, heat one end with a heat gun (until it's very soft), then clamp it between some pliers. I would not recommend you use this method on the robot, but we do all the time in testing.
Edit: ^^^ Haven't tried this myself but it does seem like a very good option for testing if you are out of connectors.
  #32   Spotlight this post!
Unread 07-12-2016, 22:20
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
These manifold blocks can be confusing to look at because the associated A and B ports are not right above each other, they're diagonal. I think they have it plumbed right (That part anyways)
Thanks for the correction Mike.
One other point I'll make is that at each connector there is a chance of an air leak and each sharp bend causes internal air drag.
When you build the system for your competition bot, I would work out how to build the system with the fewest connections and the fewest bends.
For example: instead of having 2 air paths from storage, run air to tank1, then tank2 and then to the gauge. This eliminates, 2 tee connectors, 6 connections and 4 sharp bends.
Dave
  #33   Spotlight this post!
Unread 08-12-2016, 14:14
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Mike,
Just be aware that this method reduces the burst pressure of the tubing and can allow the tube to balloon and pop.
___________________
- Tennyson, Ulysses
  #34   Spotlight this post!
Unread 10-12-2016, 20:44
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
FRC Team CC is an unknown quantity at this point
We tested it out, yet air is coming out from both valves (A and B) for one of the solenoids, but the diagrams show that it should only be coming out from one valve. For all the other solenoids, they work perfectly fine. We are not sure why this is happening, and are wondering if we need to buy a new solenoid.
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
  #35   Spotlight this post!
Unread 10-12-2016, 20:50
Does it happen with each (all four) of your solenoids mounted to the manifold?
  #36   Spotlight this post!
Unread 12-12-2016, 09:19
CC,
A few items you might want to address.
Please use only one output port on the regulator, plug the unused ports.
The photo you linked has one way valves. These are air piloted valves that you show and if you back feed them with pressure (as shown in the photo), they will leak. Another source of leaking with the manifold you show, is damaged gaskets. The gasket between the manifold and the valves must be placed correctly on the valve body and the valve must be tight to the manifold. If the gasket is not placed properly and if the valve is loose, it will leak through the gasket from one port to another.
  #37   Spotlight this post!
Unread 12-12-2016, 15:33
PVCMike PVCMike is offline
AKA: Mike Jr.
FRC #1058 (PVC Pirates)
PVCMike has a spectacular aura aboutPVCMike has a spectacular aura aboutPVCMike has a spectacular aura about
Originally Posted by Daniel_LaFleur View Post
Mike,
Totally. That's why I mentioned it was not a good idea to use on the official robot, good for a quick test if you don't have any proper on hand. We purchase off-the-shelf rated plugs to use on the real thing, although I don't think we've ever had one of our makeshift ones fail.
Coming up on year 15 with the PVC Pirates!: www.team1058.com
https://www.thebluealliance.com/team/1058
  #38   Spotlight this post!
Unread 12-12-2016, 21:32
So we tested out the solenoids with all the advice you guys have given us, and have found out that one of the solenoids was just not working properly, while all others were, so we have ordered a replacement solenoid.
FTC Team #8660
  #39   Spotlight this post!
Unread 16-12-2016, 17:49
CC,
Please reread my post. If you parallel these valves they will likely not work as intended.
