Re: [FRC Blog] 2017 Motor (and Servo?) Controllers and MXP
I have a feeling that the DMC-60 might be a Vex OEM product. NI also offers a lot of post secondary educational robotics solutions and it could be an addition to the product line that also has use in FRC. I'd be an odd move for NI to copy something so blatantly. Could anyone from Vex comment?
Wow, that makes me put a lot less faith in the product.
The Jaguar was developed and built originally by Texas Instruments (TI) (well technically a company that got acquired by TI). I don't remember National Instruments (NI) doing anything with development or support of the Jaguars, but I could have missed that.
Agreed that It's Tricky to see why an FRC team would choose to Run DMCs over the Victor SP.
The real added benefits of this come from cost per degree of freedom, since you don't need a separate motor controller for your servos you can save at-least $45 per actuation over a motor by just removing that requirement. We will all learn in January what FIRST will allow this year. |
#7
Some of the High-End Brushless Servo's can be more than $100 so it seems like there could be disparity between what the Servos teams have available to them. But we will have to wait until we see the specific rules. |
#8
Anyone know of any extra documentation on what the SD540C gives you?
#9
How come Analog Devices' ADIS16448 isn't listed as an approved device on the MXP, even though it is available in FIRST Choice?
#11
What we plug into them is up to us. Last edited by Mark McLeod : 12-21-2016 at 10:27 AM. |
#12
Ah, now I understand. Thank you.
#13
Another thing to consider is that this is only the approved list of active devices. Under R69 from last year, this is the definition of a active device:
You can read more from their blog in 2014 if you like, but rules may have changed since then. |
#15
Based on the SD540C Library documentation (http://www.mindsensors.com/reference/FRC/html/Java/) it looks like the SD540C is just a CAN enabled dumb speed controller, rather then a Talon SRX competitor.
