Go to Post This is a benefit of the district model. It brings the events back into the schools. - ezygmont708 [more]
Old 12-16-2016, 11:28 PM
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Re: [FRC Blog] 2017 Motor (and Servo?) Controllers and MXP
Originally Posted by mman1506 View Post
Don't forget this scathing test by CTRE https://www.ctr-electronics.com/down...er-Testing.pdf
I believe the SD540B has the shutdown feature removed, but the underperformance otherwise is something to consider.
Are there any plans to redo this test with the SD540B/C and the DMC-60?
Edit: The DMC-60 appears to have VERY similar mounting capabilities to the T̶a̶l̶o̶n̶ ̶S̶R̶ Victor SP. The bolt hole distance is the same and there are some zip tie grooves in the same place. It also appears that one could use them as a drop-in replacement for them.
