Go to Post It is very difficult for a large, inexperienced, impatient group to create order from chaos. - Wayne TenBrink [more]
Unread 12-18-2016, 05:37 PM
snorthey snorthey is offline
snorthey is an unknown quantity at this point
Tool list .rookie team
Hello,
We are anew rookie team... with minimal budget what would you list as the MUST HAVE tools.
We are plannning a giving tree for a family night at school and want to make the list count...
Suggestions...
Thanks
Unread 12-18-2016, 05:47 PM
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
Re: Tool list .rookie team
Since you're on a budget, I'm going to go the route we went for a couple years. We didn't have access to a space where we could set up permanent bench tools, so here's a list of essential hand tools.
  • Wire Strippers
  • Wire Cutters
  • Crimpers
  • Pliers
  • Socket Wrench Set
  • Allen key set
  • Drill/Impact Driver
  • Drill bit/hex sets for the drill/impact driver
  • Jigsaw
  • Angle Grinder
I'm probably missing a few, but these are what I can think of off the top of my head.
It's not a tool, but make sure to have plenty of hardware like bolts/nuts/etc.
Unread 12-18-2016, 05:51 PM
Lireal Lireal is offline
AKA: Alex Colello
FRC #2141 (Spartonics)
Lireal is on a distinguished road
  • Wire Strippers
  • Wire Cutters
  • Crimpers
  • Pliers
  • Socket Wrench Set
  • Allen key set
  • Jigsaw
  • Angle Grinder
In addition to these, you should also have a drill press and bandsaw. They are necessary for the majority of our manufacturing.
Unread 12-18-2016, 05:58 PM
FRC #5202
I would definitely suggest these, but I'm not sure about what their budget constraints are. They did say "minimal" budget. That's why I went the hand tools route.
Unread 12-18-2016, 06:04 PM
Billfred's Avatar
Billfred Billfred is offline
There are a few threads on this you can search for, but if you stranded me on a desert island, here's my list:
1) The tool list to build the Kickoff kit drivetrain. Obviously, we don't know what is in the Kickoff kit drivetrain this year (and those that do aren't sharing), but here's what it was last year (PDF link). FIRST has blogged that this year's Kickoff kit drivetrain will be "similar".
2) Drill bits for that drill.
3) Probably some other size wrenches. Lowe's usually sells them in a combo pack anyway.
4) Metal files. File parts as you go to knock off sharp edges, and you'll make your inspector a very happy person.
5) A pop riveter. With some rivets, some 1x1 square tubing at the hardware store and some angle or flat aluminum, you can create a structure that will achieve the game challenge. (You can optimize this further with some sheetmetal fabrication, but I've made it work with just that.)
6) Hopefully, a chopsaw with a metal cutting blade. This will make fabricating with tube and a pop riveter infinitely faster.
7) Zip ties. Being able to secure your wiring and make it legible is a major key to troubleshooting issues.
8) Staple gun. You will use it to build your bumpers.
9) (Optional, but recommended) A can of spray paint. See what I said earlier about files? Spray-painting the robot comes with a caveat: having to file afterwards will ruin the finish. Kids like a good-looking robot. So this is your incentive. As soon as we started painting, sharp edge issues all but vanished.
You probably don't need to own these--someone in your circle probably has one you can use for a bit:
1) Table saw. Bumpers are going to be used next year, and historically that means the ability to cut 5" wide pieces of 3/4" plywood.
Unread 12-18-2016, 06:06 PM
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Absolute bare bones tool list. You can build a great robot with just these tools, judicious use of COTS parts, consumables like tape/zip ties, and some creativity:
-Safety glasses
-Allen wrench set. Probably the most important item to have multiples of as they get used in parallel a lot and go missing easily, especially just buying bulk of sizes you use all the time. Must-have sizes for my team's standard fasteners of choice are 5/32" and 3/32".
-Adjustable wrenches
-Hacksaw
-A few C-clamps
-Hammer
-Vice grips
-Wire stripper/cutter/crimper
-Cordless drill, bits
-Files
-Shop-Vac
-Carpenter's Square, rulers, tape measures, or other measuring devices.
Not quite vital, but still extremely important:
-Socket wrench set
-Soldering iron
-Jigsaw (or tin snips, in a pinch)
-Rivet gun (if using rivets, which I recommend especially if you're on a budget)
-Chain break (if using chain)
-Multimeter
-Bench vice
-Tap and Die set
-Dremel tool, grinding bits and cutting wheels
-Staple gun (for bumpers)
Pricier or less vital, but super great to have if you can get them. Not a complete list by any stretch:
-Bandsaw
-Drill press
-Bench grinder
-Benchtop lathe
-Miter saw and appropriate blades
-Calipers
-Heat gun
-Air powered rivet gun
Or you can just have the people at Home Depot rip the wood to 5" when you initially buy it.
Unread 12-18-2016, 06:59 PM
Dwight_2's Avatar
Dwight_2 Dwight_2 is offline
AKA: Dwight Howard
FRC #5842 (Royal Robotics)
Rookie Year: 2016
Dwight_2 is an unknown quantity at this point
Thumbs up Re: Tool list .rookie team
Originally Posted by snorthey View Post
Hello,
Suggestions...
Thanks
Good luck to you guys this year we were rookies last year and made it to the championship hope you can do the same and I don't have anything to add to the lists already posted.
Systems Integration supervisor, CAD team, Drive team, Programming team (2016), Student team Co-Leader, Documentation Chair (2017)
"It Doesn't Get Easier. You Just Get Better."
Unread 12-18-2016, 07:01 PM
Nate Laverdure's Avatar
FRC #2363
Try to get this done on a slow weekday night if you can.
Signed,
The people behind you in the queue for the panel saw
Unread 12-18-2016, 07:55 PM
ctt956 ctt956 is online now
Overanalyzing the Hints
FRC #0900 (♞The Zebracorns♞)
Team Role: Student
Rookie Year: 2016
ctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to beholdctt956 is a splendid one to behold
In addition to what others have already posted:
Bench vises
Reciprocating saw(Sawzall) - With the proper blade, can cut anything you would use on your robot, however it can be a bit inaccurate due to vibrations. A jigsaw is better for thinner material and/or more precision.
If you (intend to)use a lot of wood, maybe get a circular saw. There are also metal cutting versions for sheet metal.
I've heard oscillating multi-tools are pretty versatile and useful, but I have yet to use one myself. I would definitely consider it, though.
As Joe said above, Allen/hex keys. A lot of them. You'll be surprised how often they go missing.
Another push for cordless drills. Get a few and at least the same number of batteries. They'll be in use 90-100% of the time during build season. Also sets of drill bits; they'll go missing or break, and having duplicates allows two or more people to drill identical holes simultaneously.
That's all I can think of for now. If you're okay with used tools(in good, safe condition of course), try estate sales. You can also get good deals online at Caring Transitions Online Auctions(the tool category is on the left sidebar.) I often see bandsaws, drill presses, and tons of hand tools there. Just be aware that air compressors/tanks and fire extinguishers should be purchased new. Air tanks rust, posing an explosion risk. Fire extinguishers experience a similar effect, and will lose pressure over time. Rechargeable ones can be repaired, but you might end up spending more to fix it than you would for a new one.
Best of luck to you and your team!
"You know, it's amazing how many things you can take apart with just one ordinary screwdriver!" - Calvin, from Calvin and Hobbes
"There's nothing a little duct tape and surgical tubing can't accomplish." - Sheldon J. Plankton
Unread 12-18-2016, 08:06 PM
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
I just posted the 2016 version of the rookie guide that we make, Illuminations.
https://www.chiefdelphi.com/media/papers/3304?
One of the appendixes is a pretty nice tool list.
Unread 12-18-2016, 11:54 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
The lists above are quite good, except that they forgot screwdrivers and measuring devices as #1 priorities.
Starting from scratch, my list of must have tools would include:
Top Priority:
Tape measure
Square (at least a "speed square", preferably also something much larger)
Straightedge (which might just be a length of aluminum angle)
Pencil (though ultra-fine sharpies are even better)
Hand Drill, with basic set of twist bits plus a step bit and perhaps select spade bits (which cut aluminum nicely). Screwdriver and allen driver bits are also a great addition.
Hacksaw
Wood Saw (preferably a back saw with a miter box that can cut 1"x6" board and 2-1/2" round pool noodles)
Screwdriver set
Hex/Allen driver set (those "swiss army knife" sets are wonderful)
combination wrench set
Basic set of files, including flat and round
Knife
Scissors, good enough to cut heavy bumper fabric among other things
Pliers: slip joint, needle nose, and diagonal cutters at a minimum.
Automotive terminal crimper
Basic wire stripper
Staple gun (I just can't imagine making bumpers without staples)
Next-level priorities would include:
Ratchet wrench set
Electric Saw (either miter chop saw or portable band saw; both is even better)
Electric "hammer drill"
Drill press (benchtop is OK, floor model as an upgrade)
Calipers (vernier if you are strapped for cash; digital if you can afford it)
Dremel tool kit (rarely the best solution, but useful for lots of stuff!)
Blind rivet setter
Angle and/or Bench grinder (preferably both)
Bolt cutters (useful for rough cuts in metal stock as well as bolts)
Anderson Power Pole crimper tool
Dupont (0.1" pitch header connector) crimper tool
"automatic" wire strippers (which grab, cut, and pull on a single squeeze)
Unread 12-19-2016, 12:26 AM
If you do not have safety glasses, you need to get some. MINIMUM one pair per team member, but remember that you'll somehow have to account for lost glasses and people that want to visit while you're making chips (cutting, drilling, and filing all generate chips or dust, and some of those tend to throw chips). You could have every team member get a pair on their own, and just get about a dozen for "shop spares". Mark the team-owned ones so people will leave them in the shop...
Maybe a couple of pairs of gloves, too, for jobs that don't involve spinning or reciprocating tools (or robot parts).
As far as measurement, there's a couple I haven't seen yet...
Scale: Length. Looks like a ruler, but has marks for decimal portions of an inch. Use this as your straightedge--get a couple in different lengths. McMaster has 'em in the $10-$25 range.
Scale: weight. For some reason, knowing how much a part weighs before it goes on the robot is very useful--small scale for that, and another that can handle the whole robot (say around the last week of build...), will come in handy.
Unread 12-19-2016, 01:17 AM
FRC #5202
Alternatively, you could put a tote on a smaller scale, tare it, then put the robot on top of the tote. A bit of a janky solution, but worked well for us.
Unread 12-19-2016, 01:23 AM
I didn't say HOW it could handle it--but it needs to have the weight capacity, minimum 150 lb. A smaller scale is handy for subassemblies.
Unread 12-19-2016, 11:05 AM
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
What, you don't have a platform scale in your bathroom?
...maybe I need to lose some weight
"If I'm going to mentor someone, I'm going to be involved in their life as a positive force." -Mechvet
