Re: Steampunk wiring - wiring color
In 2012, it was ruled that painted wire didn't change its color. Logically, then, a copper color painted wire should be fine. *
Brown/blue are standard colors for wiring and could better looking than red/black if you are going that deep into a steampunk theme.
It is fully within past years rules. I have seen teams use both schemes in robot wiring to denote different types of DC circuits. |
I'm imagining bringing that q&a to the pit and arguing with Al about the definition of a stripe.
Argue????? Me???
I cannot speak to 2017 rules other than to remind everyone that the wire color codes have changed very little in decades. The colors are chosen from the NEC and other worldwide standards for low voltage DC wiring. To go a step further, to be "steam punk", electrics would need to be powered from a steam turbine operated dynamo but electric wiring would still be required to follow all rules as they would apply. As to the steam powered dynamo, I would look carefully at whatever rules would replace or supplement 2016 rules R1, R31, R35, R36, R38, and the entire pneumatic section. Just saying... |
Please don't make an already difficult job unbearable ........ Color coding is there for a reason and you shouldn't poke bears with a sharp stick.
https://www.chiefdelphi.com/forums/s...d.php?t=109855
FIRST and the inspectors, are pretty set on the rules. A couple of years ago, we wired our dc motor power with black wire with yellow tracers, and the inspectors at Waterford made us cover the yellow tracer with black tape during inspection. I work in industrial controls, we are panel build shop, and I have access to a bunch of wire, that is donated to the team, so I like to use tracer colors to segregate function and amperage loads, but after that, we stick with red and black. Don't poke the bear. |
#7
After our own wiring snafu last season... I, for one, am not going to risk poking bears with sticks this year |
#8
As said by others, it's probably best to not poke the bear. Sleeving would likely be your safest bet.
However, it's an odd thing to note that FRC doesn't always follow standards to the letter. Battery connectors (Anderson SB50s) are traditionally red for 24V and yellow for 12V. FRC teams use red on everything (on every robot I've ever seen, with the exception of grey for pneumatics.) |
#9
Yellow - 12v Orange - 18v Red - 24v Gray - 36v Blue - 48v Green - 72v Black - 80v Brown - 96v Purple - 120v White - 144v |
#10
As for following standards: ![]() Last edited by Logan Byers : 12-21-2016 at 01:41 PM. Reason: XKCD Standards Inclusion |
#11
No rule, but SB-50 connectors are keyed by color. So a purple one wouldn't fit a red one. (Pink is an exception, presumably so donated connectors are obvious.)
#12
What if you spray painted a wiring wrap... not the wiring... like the cord keeper... and other devices like the zip ties...
#14
And then, remember the whole point of color coding - so that people KNOW what voltage/polarity/signal the wire is carrying. If your spray paint obscures or miselads people as to what is going on, my advice is DON'T DO IT, even if it is legal under the letter of the game manual. |
#15
A couple of words of caution: If you paint the loom, make sure you find a flexible enough paint. Otherwise it will tend to chip and flake. I have seen this a lot on harnesses outside of robotics. While it looks cool initially, the flaking of paint can make it look trashy later on. Use wire labels or indicators to help trace your wires if you are using wiring loom. This can also help if you make a wiring diagram which will get you browny points towards things like Quality award. |
