Go to Post Did you know that if a G7, G27, G28, and G20 occur in that order at the same time, then the referee will appear to be doing the "YMCA"? :) - Jack Jones [more]
Unread 20-12-2016, 16:39
afera's Avatar
afera afera is offline
FTA - FIRST in Michigan
AKA: Alexander Fera
FRC #0503 (Frog Force)
afera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to beholdafera is a splendid one to behold
Re: [FTC]: FTC Vortex Counter
Originally Posted by MattRain View Post
When looking at this, did you have a second group of scorekeepers running this? Or the same group, along with the regular scoring system?
We had two "Scorers" (one per alliance) standing by the Corner Vortex at each field to count the Center and Corner Vortex. The Refs also verified (with manual counters) before writing down on the scoring sheet and handing it off to the Scorekeepers (Different Volunteers).
Note: At all of our events we used two fields.
Alexander Fera
FIRST Technical Advisor (FTA) and Control System Advisor (CSA) - FIRST Robotics Competition
Lead FIRST Technical Advisor (FTA) and Assistant Affiliate Partner - FIRST Tech Challenge
FIRST in Michigan, Facebook and Twitter
2017 FRC: Lakeview, St. Joseph (IN), Gaylord, Woodhaven, Livonia, MSC and CMP - St. Louis
2016-2017 FTC: Big Rapids, Pestokey, Marysville, Coloma, Concord, MSC, North Super Regional and CMP - Houston
Volunteer Since 2009 and Alumni/Mentor of 503 Frog Force ('11)
FRC FTA since '14 and CSA since '12 | FTC FTA and CSA since '11
LinkedIn
