Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 20-12-2016, 11:35
Robodragons4630 Robodragons4630 is offline
CHS Robodragons Programming
AKA: Noah Jarnigan
FRC #4630 (Robodragons)
Robodragons4630 is an unknown quantity at this point
PID
Using LabVIEW I can use a auto PID where it fixes the PID as it is being ran. Can I do this with C++ and how do I use a C++ PID loop. I have used a PID loop before in LabVIEW but I can't understand how to do it on c++ using the wpiLIB. If you can provide simple code to help or give a website other than wpiLIB that would be appreciated. Thanks!
Unread 20-12-2016, 12:19
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: PID
I know you said site that is not WPILib but it actually has some useful info
http://wpilib.screenstepslive.com/s/...rs-pid-control
Make sure you've read this. It has extensive information and example code
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 20-12-2016, 13:07
AKA: Noah Jarnigan
Re: PID
Thank you . For some reason after 20 mintues of googling that page didn't show up for me.
Unread 20-12-2016, 14:45
Re: PID
I'm curious what you mean by this. Would you please explain?
Unread 20-12-2016, 16:55
AKA: Noah Jarnigan
Re: PID
This code isn't as smooth as a perfectly tuned PID but we couldnt use that because the thing we used the PID rotated vertically on a shaft so the PID needed to constantly update because based on the angle of our shooter gravity would effect it differently.
Unread 26-12-2016, 12:20
sspoldi's Avatar
sspoldi sspoldi is offline
Steven Spoldi
AKA: Steve Spoldi
FRC #0230 (Gaelhawks)
sspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to behold
Re: PID
Hi Noah,
Normally I wouldn't post (relatively) untested code, but if simple is what you want the attached may work for your needs. I just tossed this together the other day (I intend to make this a development task for some of our software kids, if you're on Team 230 stop looking!). BTW, we use the simple robot class with C++ and do our own loops, just seems to be easier that way.
Cheers,
Steve.
P.S. Don't tell MamaSpoldi I'm posting code, I'll get in trouble
File Type: c pid.c (972 Bytes, 10 views)
File Type: h pid.h (300 Bytes, 4 views)
File Type: c example.c (453 Bytes, 10 views)
Unread 04-01-2017, 13:54
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is offline
Programming Mentor
AKA: Laura Spoldi
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
Re: PID
Originally Posted by sspoldi View Post
Hi Noah,
Cheers,
Steve.
No worries. I am always happy to post our code whenever it is needed by someone. Besides, as you mentioned, that is your code, not code developed by our students. Either way it is always good to share!
Save
