Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 20-12-2016, 20:21
Re: Data Logging Through Driverstation
There are a number of good suggestions in this thread, but let me add a few points.
The OS and other utilities log things to the roboRIO flash all the time. A team is running with user privileges It should be pretty easy to look at your log file design, estimate usage, and determine whether a USB stick or RIO flash is the right approach. Also, if needed, you may want to disable buffering to on file open to better deal with power loss.
If you find that your CSV file is too large, binary files are often much smaller, typically a factor of five to ten.
Depending on the rate you want to log at, you may also want to consider network table logging. This logs the data at more like 10 Hz, but it automatically logs every variable update and it is built into the default DB. It is possible to build a custom DB and log faster if you wish.
I highly encourage you to log data, though. I love it when teams have data to understand what their robot is doing.
Greg McKaskle
