Go to Post Quitting when faced with adversity is not the answer. We have to figure out a solution within the constrainsts applied. - Rob [more]
Unread 20-12-2016, 20:39
Calasada Calasada is offline
FRC #2783
Calasada is an unknown quantity at this point
Confusing Issues with Swerve
So our team has been working off-season on programming swerve drive in Java. We already got help from here before but have run into a very puzzling problem that no one can figure out. We added efficient movement in the modules and that seemed to cause the problem. Two of the wheels, the front left and rear right, always go 180 degrees further when rotating for the time after a deploy. This causes the wheels to return to the forward heading causing the encoder to read 360 degrees. This screws up the efficiency code even further. We have no idea why it only affects 2 of the 4 modules, and the problem itself seems very strange. I'm happy to explain the problem further, I probably didn't explain it very well. Our entire code for the subsystem is here:
public class SwerveDriveBase extends Subsystem {
	private SwerveModule frMod;
	private SwerveModule flMod;
	private SwerveModule rrMod;
	private SwerveModule rlMod;
	private AHRS navSensor;
	private final double p = 0.05;    //0.015;
	private final double i = 0.0025;    //0.005;
	private final double d = 0.005;    //0.125;
	private boolean was = false;
	final private double ENCODER_TICKS_FOR_ADJUSTER_TRAVEL = 1;
	public class PIDOutputClass implements PIDOutput {
		private VictorSP motor;
		public PIDOutputClass(VictorSP motor) {
			this.motor = motor;
		@Override
		public void pidWrite(double output) {
			motor.set(output);
	public class SwerveModule {
		VictorSP swivelMot;
		CANTalon driveMot;
		Encoder enc;
		PIDController pidCont;
		PIDOutputClass pidOut;
		public SwerveModule(
				VictorSP swivelMot,
				CANTalon driveMot,
				Encoder enc) {
			this.swivelMot = swivelMot;
			this.driveMot = driveMot;
			this.enc = enc;
			pidOut = new PIDOutputClass(
							swivelMot
			pidCont = new PIDController(
							p, i, d,
							enc,
							pidOut
			pidCont.setInputRange(0, 360);
			pidCont.setContinuous();
			enc.setDistancePerPulse(0.875);
			enc.setSamplesToAverage(127);
		public void setModule(double angle, double speed) {
			if(angle < 0) {
				angle += 360;
			double curAngle = getAngle();
	    	if(Math.abs(angle - curAngle) > 90 && Math.abs(angle - curAngle) < 270 && angle != 0) {
	    		angle = ((int)angle + 180)%360;
	    		speed = -speed;
	    	setAngle(angle);
	    	setSpeed(speed);
		public void setAngle(double angle) {
			pidCont.enable();
			pidCont.setSetpoint(angle);
		public void setSpeed(double speed) {
			driveMot.set(speed);
		public void setSwivel(double speed) {
			swivelMot.set(speed);
		public double getEncPercent() {
			return Math.abs(enc.getDistance() / ENCODER_TICKS_FOR_ADJUSTER_TRAVEL);
		public double getAngle() {
			if (enc != null) {
				return (getEncPercent());
			} else {
				return -1.0;
		public void setBrake(boolean bool) {
			driveMot.enableBrakeMode(bool);
	public double cosDeg(double deg) {
		return Math.cos(Math.toRadians(deg));
	public double sinDeg(double deg) {
		return Math.sin(Math.toRadians(deg));
    public SwerveDriveBase() {
    	super();
    	//Makes sure navX is on Robot, then instantiates it
    	try {
	         navSensor = new AHRS(SPI.Port.kMXP);
	     } catch (RuntimeException ex ) {
	         DriverStation.reportError("Error instantiating navX MXP:  " + ex.getMessage(), true);
    	frMod = new SwerveModule(
    					new VictorSP(RobotMap.FRONT_RIGHT_SWIVEL),
    					new CANTalon(RobotMap.FRONT_RIGHT_WHEEL),
    					new Encoder(new DigitalInput(6),
    								new DigitalInput(7))
    	flMod = new SwerveModule(
    					new VictorSP(RobotMap.FRONT_LEFT_SWIVEL),
    					new CANTalon(RobotMap.FRONT_LEFT_WHEEL),
    					new Encoder(new DigitalInput(0),
    								new DigitalInput(1))
    	rrMod = new SwerveModule(
    					new VictorSP(RobotMap.REAR_RIGHT_SWIVEL),
    					new CANTalon(RobotMap.REAR_RIGHT_WHEEL),
    					new Encoder(new DigitalInput(2),
    								new DigitalInput(3))
    	rlMod = new SwerveModule(
    					new VictorSP(RobotMap.REAR_LEFT_SWIVEL),
    					new CANTalon(RobotMap.REAR_LEFT_WHEEL),
    					new Encoder(new DigitalInput(4),
    								new DigitalInput(5))
    public void initDefaultCommand() {
        setDefaultCommand(new SwerveDrive());
    //Small, simple tank drive method
    public void tankDrive(double leftValue, double rightValue) {
    	if (DriverStation.getInstance().isFMSAttached() && DriverStation.getInstance().getMatchTime() < 4) {
    		setRobotBrake(true);
    	} else {
    	frMod.setSpeed(rightValue);
    	rrMod.setSpeed(rightValue);
    	flMod.setSpeed(leftValue);
    	rlMod.setSpeed(leftValue);
    //Method for calculating and setting Speed and Angle of individual wheels given 3 movement inputs
    public void swerveDrive(double fbMot, double rlMot, double rotMot) {
    	//Swerve Math Taken from: https://www.chiefdelphi.com/media/papers/2426
    	double curAngle = getNavSensor().getAngle();
    	double temp = fbMot*(cosDeg(curAngle)) + rlMot*(sinDeg(curAngle));
    	rlMot = (-fbMot*(sinDeg(curAngle)) + (rlMot*(cosDeg(curAngle))));
    	fbMot = temp;
    	double L = 1.0;
    	double W = 1.0;
    	double R = Math.sqrt((L*L) + (W*W));
    	double A = rlMot - rotMot*(L/R);
    	double B = rlMot + rotMot*(L/R);
    	double C = fbMot - rotMot*(W/R);
    	double D = fbMot + rotMot*(W/R);
    	double frSpd = Math.sqrt((B*B) + (C*C));
    	double flSpd = Math.sqrt((B*B) + (D*D));
    	double rlSpd = Math.sqrt((A*A) + (D*D));
    	double rrSpd = Math.sqrt((A*A) + (C*C));
    	double t = 180/Math.PI;
    	double frAng = Math.atan2(B, D)*t;
    	double flAng = Math.atan2(B, C)*t;
    	double rlAng = Math.atan2(A, C)*t;
    	double rrAng = Math.atan2(A, D)*t;
    	double max = frSpd;
    	if(max < flSpd) max = flSpd;
    	if(max < rlSpd) max = rlSpd;
    	if(max < rrSpd) max = rrSpd;
    	//I'm so sorry Jake
    	if(max > 1) {
    		frSpd /= max;
    		flSpd /= max;
    		rlSpd /= max;
    		rrSpd /= max;
    	//Set Wheel Speeds and Angles
    	frMod.setModule(frAng, frSpd);
    	flMod.setModule(flAng, flSpd);
    	rrMod.setModule(rrAng, rrSpd);
    	rlMod.setModule(rlAng, rlSpd);
    //Returns navX sensor ?
    public AHRS getNavSensor() {
    	if (navSensor != null) {
    		return navSensor;
    	} else {
    		return null;
    public void setRobotBrake(boolean bool) {
    	frMod.setBrake(bool);
    	flMod.setBrake(bool);
    	rrMod.setBrake(bool);
    	rlMod.setBrake(bool);
and the efficiency test specifically is here:
      speed = -speed;
Thanks in advance for any help.
