Re: Team 4499's first Homemade Gear!
That looks awesome! Quick question: how'd you locate the center of the gear for the pilot hole and the broaching? |
We used a lathe to get the material to the correct diameter and then drilled the 1/2" hole for broaching on a three ton press. We used a three jaw to clamp up on the stock.
You know what really cuts my gears? Those Highlander guys!
Looks nice, I would suggest making gear stock and cutting pieces off of it as it is likely to be more time efficient. Also use 7075 if you are going to be putting it on a robot, the cost is worth it. If you are not already aware, 7075 has nearly the same structural properties as 1018 steel but the same softness as aluminum. nice and strong but will wear much quicker. |
Gosh guys! I'd finally got our HAAS working this month and then you guys have to show up and one-up me?
But seriously, this is awesome! I don't think I've seen your guys new (old) VF2 in person though. I'll have to come check it out sometime. Thanks for the help you gave us with HAAS training a bit ago. One last question, I can't tell from the picture, does your HAAS have an automatic tool changer? |
