Go to Post Please Note: Elgin is still wearing his safety glasses. Practice safe Dewing. - JohnBoucher [more]
  #46   Spotlight this post!
Unread 05-07-2016, 10:25
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
Re: Electrical connectors on control system items
Originally Posted by sraque View Post
We love the Anderson Powerpoles and the (cheaper) version of the Hansen Hobbies Molex connectors from Digikey.
can you post the part number for these cheaper versions?
  #47   Spotlight this post!
Unread 12-12-2016, 08:40
Greg,
The JST style you linked are used in equipment I work on everyday. They are good for small signal and DC or status. Most manufacturers will use different size connectors to avoid having assemblies plugged in to the wrong connector.
The other connectors you link I dislike for some very serious reasons. I have seen these appear on robots from time to time because the sellers claim high current specifications for these connectors. However, in real life, none of the specifications match the capabilities of the connectors. I have done some research into these connectors and the same connector is rated anywhere from 5 amps to 60 amps and none of the connectors carry a UL rating. The Anderson contacts are extensively tested by UL for continuous current over a 24 hour test period. The testing includes temperature rise, contact retention and series resistance measurements. Above all else, they are a positive locking connector where the others are not. Gold plating is not going to make them better especially when the gold breaks off the base metal.
My humble opinion.
  #48   Spotlight this post!
Unread 20-12-2016, 09:22
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
arichman1257 is on a distinguished road
This is just my opinion on the connectors mentioned.
.1 inch headers (PWM) - As long as the pins on the roboRIO or on the male connector don't bend they're great to use. The cables themselves are somewhat bothersome when they're not long enough to reach because the connectors don't provide an easy way to connect wire to wire without being prone to disconnecting.
Weidmuller - Probably my favorite connector that is used for the small wires. They are easy to press (I have been known to just use my finger in a pinch) and hold the wire well when they have been used properly.
Wago - They work very well for large wires. When the PDP isn't in a convenient position they can be hard to work with if not given the proper care. I don't really have a problem with them but I know that some people do.
Screw terminals - Annoying when they're not placed well and sometimes the screw is dropped. But otherwise reliable if used correctly.
Spade terminals - I don't like them. They always break on me.
Anderson Powerpole -My favorite way to connect wires to each other hands down. (When current draw allows)
IDC connectors - They work well enough. Good way to join many wires to pins.
USB - I haven't really had them in use on an FRC robot enough to give an opinion.
Barrel jack - They pull out when tugged on and should be secured with a ziptie or something like that. but if theyare not abused (pulled on) they work well
RJ45/RJ11 - They're great until the little clip on them breaks
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
  #49   Spotlight this post!
Unread 20-12-2016, 09:40
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
I appreciate all the post and comments. Wiring, connectors and plugs is on our list of improvement this year.
Is there a web page or document that describes the most used wires type and connectors used in FRC and different options that are available? even a poster to use as a reference? does your team have a document that describe the standard you are using?
Any info would be appreciated.
  #50   Spotlight this post!
Unread 20-12-2016, 09:50
AKA: Alan Richman
I don't personally have experience with the other 3 but the XT and dean's connectors look good.
  #51   Spotlight this post!
Unread 20-12-2016, 10:09
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
<shameless plug incoming>
As far as I know, but this could be a great resource to put on the FIRST Wiki! In my free time over the next few days I may start this page.
EDIT: Went ahead and created this page with some basic info, feel free to add more to it here!
F4 Network Website Designer
2010-2012: A Whole Buncha FLL Teams; Team Spirit, Gracious Professionalism Award winner
2015-Current: FRC 1982, Captain, Electrical Lead
Beginning FIRST Volunteer
Moderator on the FIRSTwiki
  #52   Spotlight this post!
Unread 21-12-2016, 14:51
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We just put in an order for the Molex latching .1 connectors from Arrow.com
Name | Part # | Qty | Price | Link
Male Housing| 701070002 | 100 | $0.20 | https://www.arrow.com/en/products/0701070002/molex
Female Housing | 50579403 | 100 | $0.11 | https://www.arrow.com/en/products/0050579403/molex
Male Pin* | 16020107 | 300 | $0.05 | https://www.arrow.com/en/products/0016020107/molex
Female Pin* | 16020086 | 300 | $0.04 | https://www.arrow.com/en/products/0016020086/molex
*Note that these pins aren't Bulk packaged they are still on their cut strips.
  #53   Spotlight this post!
Unread 21-12-2016, 22:59
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is online now
AKA: Clint Brawley
FRC #0364 (Fusion)
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
While more expensive than a ziptie ($0.49 for 5), these are great for ensuring that anderson powerpoles 15/30/45 stay together.
https://powerwerx.com/powerpole-conn...retention-clip
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
