Go to Post Take care of what's there and you never need a replacement. - Rich Kressly [more]
  #61   Spotlight this post!
Unread 12-21-2016, 10:26 AM
BoilerMentor BoilerMentor is offline
FRC #1747
BoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond reputeBoilerMentor has a reputation beyond repute
Re: Inter-District Play in 2017
Originally Posted by Taylor View Post
As a supporter of Indiana robot builders, I'd like to say the following about interdistrict play in 2017:
Bring it.
I ain't skeerd.
I'd like to echo this sentiment, both as an FRC mentor for 1747 and as an accessory to the planning committee of the Tippecanoe district both last season and for this upcoming season. The Michigan teams that attended our event last year were a pleasure to work with and great competitors. We welcome our brothers and sisters in FIRST from the north.
If you're worried about Michigan teams coming down to Indiana to hurt your chances, that may say more about you or your team than it does about the teams coming down. Good luck this season!
2006-2008 FIRST Team 1741 Red Alert-Founding Student
2008-2011 FIRST Team 1747 Harrison Boiler Robotics-College Mentor
2012 FIRST Team 4272 Maverick Boiler Robotics-Founding College Mentor
2013-Present FIRST Team 1747 Harrison Boiler Robotics-Engineering Mentor
  #62   Spotlight this post!
Unread 12-21-2016, 11:23 AM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by Theseusgoats View Post
But the same can be said of your team as well can't it? I mean, for the most part, teams that do extra events for practice are usually strong competitors, meaning that they will tend to do well. If somehow the top 8 are all MI teams, then you can't get as many points and neither can anyone else at the competition. This gives them a disadvantage in comparison to teams who don't attend the event if they do end up being able to rank highly. Obviously, this is theoretical as it assumes that MI teams are somehow going to be head and shoulders above all the IN teams at the event.
The bolded phrase is the key phrase.
Obviously you always want your team to perform well. But that doesn't change when you're facing a Michigan team or an Indiana team. You want to win the matches you're in. You want to seed high. Etc.
What changes between an in-district and an out-of-district is that points "disappear" when earned by an out-of-district team. It's beneficial for your ranking efforts if every point you fail to earn ends up disappearing, rather than going into the ranking of one of your in-district opponents.
Think of it this way. Say your team in ranked 5th at your event. If you're ranked 5th at your event and the 4 teams ahead of you are from Indiana, you take the 5th most standing points away from the event. If you're ranked 5th, and the 4 teams ahead of you are from Michigan, you take the most standing points away from the event. The total points you receive is the same in each scenario, but the latter scenario results in 4 fewer Indiana opponents gaining a lead on you in the district standings.
  #63   Spotlight this post!
Unread 12-21-2016, 11:35 AM
Carolyn_Grace's Avatar
Carolyn_Grace Carolyn_Grace is offline
Build bridges not walls.
AKA: Carolyn Beyer
FRC #1024
Carolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond repute
Originally Posted by BoilerMentor View Post
I'd like to echo this sentiment [....] We welcome our brothers and sisters in FIRST from the north.
Sentiment Thirded.
I can't WAIT to see our InF teams play against FiM teams!
Points can't be stolen because points must be earned.
If you didn't earn those points against a Michigan team, then it's not the Michigan's team fault for beating your team. It's your team's fault for not EARNING them. There aren't participation medals in FRC anymore.
Hey I'm just not trying to offend either the IN or the MI teams here.
So, who are you? What team are you associated with? Why do you not have these things listed in your CD profile?
"It is change, continuing change, inevitable change, that is the dominant factor in society today. No sensible decision can be made any longer without taking into account not only the world as it is, but the world as it will be." -Isaac Asimov
  #64   Spotlight this post!
Unread 12-21-2016, 11:49 AM
Data Nerd
FRC #0079
Uh, why do they need to have a team listed?
  #65   Spotlight this post!
Unread 12-21-2016, 11:54 AM
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
IDK I'm pretty proud of my team, I assume others feel the same.
Also I'm pretty proud of myself and my FRC accomplishments, and I don't feel the need to hide behind an anonymous account.
But to each his own.
Hi!
  #66   Spotlight this post!
Unread 12-21-2016, 11:57 AM
AKA: Carolyn Beyer
FRC #1024
They don't. It's not a requirement. Maybe they aren't even associated with any team. Who knows?
This person has been very vocal lately, and I personally believe that accountability by saying who you are can lead to more thoughtful posts on Chief Delphi.
  #67   Spotlight this post!
Unread 12-21-2016, 12:09 PM
Data Nerd
FRC #0079
Eh, some folks like their privacy. I can respect that. I don't think calling them out on that is really a great idea.
Plus, everyone knows who I am and many would claim my posts aren't "thoughtful"
  #68   Spotlight this post!
Unread 12-21-2016, 12:13 PM
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
Conversely, at another event w/ only district teams, 4 teams gain more points than you.
Not sure the system is flawed, but then again?? If you’re the best team from your district at a district event, it might be a bit tough to see another district team gain more points being the 3rd best at a different event.
  #69   Spotlight this post!
Unread 12-21-2016, 04:43 PM
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
Looking at the PNW, there looks to be no teams coming to any PNW events, more likely than not because of the cost, as most of the other districts are in the Midwest/East Coast and the sheer cost of travel...
it would be nice if we had more districts out here, or if we just take Idaho...
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #70   Spotlight this post!
Unread 12-21-2016, 05:12 PM
foote stepped in
AKA: E. Foote
FRC #0868
In the future, I think it would be neat to have districts setup with overhead for more inter-district play, I.E. we'll allocate an extra 10-20% for empty spots in a competition with the expectation that other districts do the same. Maybe an extra week 1 event?
I have no idea how that could work or the type of horse trading required, it also assumes teams in the district wanting 3rd plays are sated. Maybe teams signing up for their 3rd event between districts could trade events?
Just a thought.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
  #71   Spotlight this post!
Unread 12-21-2016, 05:30 PM
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I was more referring to the various posts in this thread regardless in-event strategy. Specifically the posts saying teams considered not picking Michigan teams or strategizing so that Michigan teams would not be as effective in their event. These strategies are actively harmful to your own ranking efforts.
  #72   Spotlight this post!
Unread 12-21-2016, 06:30 PM
mklinker's Avatar
mklinker mklinker is offline
Coach FRC4485
AKA: Mike Klinker
FRC #4485 (Tribe Tech Robotics)
mklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to beholdmklinker is a splendid one to behold
I look forward to competing with MI teams. If we are better then we will have earned the points. If not we will have been exposed to even more teams and ideas. Either way sounds like a win to me......and isn't that what FIRST is supposed to be about?
Mike Klinker Mentor, Tribe Tech Robotics FRC 4485
2016 Walker Warren District Semi-Finalist
2015 Indiana District Championship Semi-Finalist, Purdue District Quarter Finalist, Kokomo District Quarter Finalist, R2OC Finalist
2014 Boilermaker Regional Quarter Finalist
  #73   Spotlight this post!
NicusTM's Avatar
NicusTM NicusTM is offline
AKA: Nic
FRC #3216 (Missoula Robotics Team)
Team Role: Student
NicusTM is an unknown quantity at this point
...and western MT
  #74   Spotlight this post!
Unread 12-21-2016, 07:38 PM
MikLast's Avatar
CAO/Drive Coach
Originally Posted by NicusTM View Post
...and western MT
there's no reason not to...
  #75   Spotlight this post!
Unread 12-21-2016, 07:54 PM
frcguy's Avatar
frcguy frcguy is offline
Unregistered Unuser
AKA: Nicholas Dal Porto
FRC #5940 (B.R.E.A.D.)
Team Role: Tactician
frcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond reputefrcguy has a reputation beyond repute
...and western MT
And Calif...
Oh wait.
2016: Team 5940 (Silicon Valley Regional Rookie All-Star and Quarterfinalist, Curie Quarterfinalist)
Volunteer: 2016 (Chezy Champs Field Reset, Capital City Classic FTA, MadTown ThrowDown FTA)
