Go to Post Blue Nitrile Tread is the best smelling wheel tread. #thingsyoufigureoutat2AM - Ginger Power [more]
Go Back   Chief Delphi > Other > Math and Science
Old 22-12-2016, 18:56
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: numerical solution of differential equations
What surprises me more than the gain in amplitude for Euler (which is pretty easy to guess if you consider what happens to energy at different points) is the excellent prediction of the period. I'll have to give this a look.
I was able to do a version without the two extra columns that tracked pretty closely, using the parabolic formula for constant acceleration to calculate the next position, and the average acceleration assuming constant jerk (x''') to calculate the next velocity.
x[n+1]   =  x[n]  + dt*(x'[n]  + x''[n]*dt/2)
x''[n+1] = -x[n+1]
x'[n+1]  =  x'[n] + dt*(x''[n] + x''[n+1])/2
Last edited by GeeTwo : 23-12-2016 at 11:16. Reason: Fixd sign on second equation, formatted cleaner
