Re: Confusing Issues with Swerve
An easy way to test your swerve inverse kinematics code to confirm that it is doing the computations correctly is to feed it several [fwd,str,rcw] triplets and compare the resulting wheel speeds and angles to the values computed by this swerve calculator spreadsheet. |
