Go to Post Use checklists. If it's good enough for NASA, it's good enough for FIRST. - Rick TYler [more]
Unread 23-12-2016, 13:46
Wishbonea's Avatar
Wishbonea Wishbonea is offline
FRC #2062
Wishbonea is an unknown quantity at this point
C.O.R.E. 2062 - Off Season Swerve
This is C.O.R.E. 2062's first ever swerve drive. Pictured above is the first finished module, with three more on the way.
Features:
  • Custom Bevel and Spur Gears
  • Integrated Talon SRX Controllers
  • Completely Modular
Link to CAD files:
https://grabcad.com/library/c-o-r-e-...eason-swerve-1
Code release on the way!
Unread 23-12-2016, 14:19
Cothron Theiss's Avatar
Cothron Theiss Cothron Theiss is offline
Re: C.O.R.E. 2062 - Off Season Swerve
Custom bevel gears as in you did all the tooth cutting yourself, or as in you took a COTS gear and modified it?
Unread 23-12-2016, 15:25
Wishbonea's Avatar
FRC #2062
Custom as in we made the gears from scratch, doing all the tooth cutting on a vertical mill with an involute gear cutter.
Here's a picture of all of the custom gears
