Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
Go Back   Chief Delphi > Other > Math and Science
Old 12-22-2016, 04:31 PM
numerical solution of differential equations
consider the function x = cos(t)
the first derivative is x' = -sin(t)
and the second derivative is x" = -cos(t)
so we have the differential equation x" = -x
and x = cos(t) is the analytical (true) solution to that differential equation
with initial conditions x=1 and x'=0 at t=0.
Now turn things around.
suppose we are given the differential equation x" = -x',
with initial conditions x=1 and x'=0 at t=0,
and we want to plot x and x' vs t,
but we don't know how to find the analytical solution,
so we decide to numerically integrate it using the Euler method:
x'[n+1] = x'[n] + x"[n]*dt
x[n+1] = x[n] + x'[n]*dt
x"[n+1] = -x[n+1]
See attached spreadsheet Euler.XLS to see what happens. Yikes.
Columns Xa and Va are the analytical (true) solutions for position and velocity.
Columns Xe and Ve are the Euler Method numerical solutions for position and velocity.
Now instead of using the Euler method, use the Midpoint method:
Vmid = x'[n] + x"[n]*dt/2
Xmid = x[n] + Vmid*dt/2
Amid = -Xmid
x[n+1] = x[n] + Vmid*dt
x'[n+1] = x'[n] + Amid*dt
x"[n+1] = -x[n+1]
See spreadsheet Midpoint.XLS
Columns Xm and Vm are the Midpoint Method numerical solutions for position and velocity.
Columns Vmid, Xmid, and Amid are the extra columns needed for the Midpoint Method.
Notice that even though the Midpoint method requires 3 additional columns,
you can double the step size dt,
so the computation is just as fast as Euler,
but with far better accuracy.
Old 12-22-2016, 04:46 PM
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: numerical solution of differential equations
Hi Russ!
I see you are bored, or maybe just antsy for the 2017 FIRST Robotics Competition kickoff. Either way, this is an interesting topic in numerical methods.
Question for an interested student (someone much younger than me):
Should we expect, in general, that Euler integration will be well suited to approximate monotonic systems, while Midpoint integration gives better results for periodic systems? If so, why?
Richard Wallace
since 2003
Old 12-22-2016, 04:52 PM
Yes I am very much looking forward to the Kickoff.
And I have some long-overdue hardware to return to you
Old 12-22-2016, 06:23 PM
Hitchhiker 42's Avatar
Hitchhiker 42 Hitchhiker 42 is offline
Roboter
AKA: Mark Lavrentyev
FRC #4557 (FullMetal Falcons)
Rookie Year: 2015
Hitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to beholdHitchhiker 42 is a splendid one to behold
Hi Russ!
As I understand it, the main difference between the Euler method and the Midpoint method is that the midpoint method takes the slope by connecting a point behind and a point ahead of the given point. The Euler method just takes the slope at that point at extrapolates for that step. Please, do correct me if I'm wrong.
So, a monotonic function only increases (or decreases). It seems Euler integration would be better suited (read: more accurate) because the midpoint method depends on points behind the given point that's being calculated, which will tend to keep the slope smaller than it should be, whereas because the function doesn't tend to change direction (up or down) as much (it can only go one direction - monotonic), approximating ahead will tend to be better than approximating while taking into account behind the current point as well.
2016 - NE District Championship Entrepreneurship Award
2016 - Hartford District Industrial Design Award
2016 - Waterbury District Engineering Inspiration Award
Old 12-22-2016, 06:56 PM
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
What surprises me more than the gain in amplitude for Euler (which is pretty easy to guess if you consider what happens to energy at different points) is the excellent prediction of the period. I'll have to give this a look.
I was able to do a version without the two extra columns that tracked pretty closely, using the parabolic formula for constant acceleration to calculate the next position, and the average acceleration assuming constant jerk (x''') to calculate the next velocity.
x[n+1]   =  x[n]  + dt*(x'[n]  + x''[n]*dt/2)
x''[n+1] = -x[n+1]
x'[n+1]  =  x'[n] + dt*(x''[n] + x''[n+1])/2
Last edited by GeeTwo : 12-23-2016 at 11:16 AM. Reason: Fixd sign on second equation, formatted cleaner
Old 12-22-2016, 10:44 PM
Originally Posted by Hitchhiker 42 View Post
As I understand it,...the midpoint method takes the slope by connecting a point behind and a point ahead of the given point...Please, do correct me if I'm wrong.
Where did you come by this understanding?
It seems Euler integration would be better suited [for monotonic function]...
You could easily modify the XLS I posted to test this hypothesis
Old 12-23-2016, 12:45 AM
Unless I was careless with the algebra (it happens when I'm tired),
Steve's catapult can be modeled with an ODE of the form
θ'' = k1 + k2∙cos(θ) + k3∙θ'
Attached is an Octave script that uses Octave's built-in ODE solver "lsode"
to numerically integrate arbitrary ODEs of the form x'' = f(t,x,x')
File Type: txt x''=f(t,x,x').m.txt (741 Bytes, 7 views)
Old 12-23-2016, 11:46 AM
sspoldi's Avatar
sspoldi sspoldi is offline
Steven Spoldi
AKA: Steve Spoldi
FRC #0230 (Gaelhawks)
sspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to beholdsspoldi is a splendid one to behold
Hillbilly solution:
one forward Euler integration, one backward Euler integration, less typing and good enough for government work.
Surprising how often that works...
Cheers,
Steve.
P.S. The equation (for the catapult) should be something like θ" = K1∙(K2 - θ'), θ is just along for the ride.
Old 12-23-2016, 12:03 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Originally Posted by sspoldi View Post
Hillbilly solution:
That is:
x'[n+1]  =  x'[n] + dt*x''[n]   //backward looking
x[n+1]   =  x[n]  + dt*x'[n+1]  //forward looking
x''[n+1] = -x[n+1]
It looks OK on amplitude, but overpredicted the resonant frequency by .. almost half a part per thousand. Certainly good enough for FRC.
The cosθ term is gravity acting on the boulder (and lever arm).
Old 12-23-2016, 12:36 PM
sspoldi's Avatar
Steven Spoldi
AKA: Steve Spoldi
Yea, I'd like to say we just ignore stuff like that, but sometimes it's a real factor. In 2014 we had a hammer with a 3 pound head on a 1 foot arm, gravity definitely made a difference.
Since we typically don't have a lot of time (who does), I like to get the kids to do a simple model up front, and then we do some system id and fit the actual robot behavior to a model. This way we can tune control systems quickly, and it gives them a chance to do some data based optimization in addition to a little physics up front.
Cheers,
Steve.
Old 12-23-2016, 12:41 PM
Vn+1 = Vn + An∙dt;
Xn+1 = Xn + Vn+1∙dt;
Maybe provides some insight: the above is algebraically equivalent to
Vn+1 = Vn + An∙dt;
Xn+1 = Xn + dt∙(Vn+Vn+1)/2 + ½∙An∙dt2
Old 12-23-2016, 01:31 PM
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Vn+1 = Vn + An∙dt;
..so counting the constant acceleration term twice in the position calculation mostly offsets not counting the jerk in the velocity calculation..at least in this case.
Old 12-23-2016, 03:00 PM
derivation of k1 k2 k3
Name:	k1 k2 k3.png
Old 12-23-2016, 03:58 PM
Roboter
Rookie Year: 2015
I've attached your spreadsheets modified for 1/4*x^3 + 1.
It seems that the Euler method does approximate it better.
Old 12-23-2016, 09:19 PM
@Mark: Where did you get the accel formula for columns D and G.
