Go to Post I do this stuff because...well first inspired me to become me. I now understand who i am better and what i want to do. - Marygrace [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 23-12-2016, 19:53
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Internet help
I need help setting up my new router at my house to connect to the internet.
It is a Cisco 1941 w/EHWIC-DSL-VA-A card
Connection is through bonded dsl, my provider dynamically assigns connection ip over pppoe, and my 5 static public IPs plus i have the static gateway ip that my current modem has that is in same subnet as these 5 public IPs are provided through this connection. these are in different subnets
the interface card gives me an ATM0/0/0 and Ethernet0/0/0
the router has 2 gigabyte interfaces
I need to know how to configure the router to work in front of my firewall which will do all the NAT etc.
I know basic cisco commands, just can't find much info on dsl with static public ips over pppoe.
Thanks
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
Unread 23-12-2016, 21:16
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Internet help
I do not know the full answer to your question, but I do know enough to see a possible showstopper. To clarify - are your five static public IPs located at your house behind the dynamic IP assignment, or are they located at a server farm somewhere which provides static addresses? In the second case, this seems to be a non-trivial but simple case; in the first, I am not sure that this is possible.
Unread 23-12-2016, 21:19
Scott L.'s Avatar
Re: Internet help
all ips are located at my house
Unread 29-12-2016, 16:21
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Re: Internet help
So I assume you just want to do NAT overload on your outside interface IP address?
Can you apply the command to your WAN facing interface? I haven't worked with DSL on cisco routers but I assume it would be the same as doing NAT between two ethernet interfaces
(config-if)# ip nat outside
If so you should be able to apply the following commands
(Inside interface)
(config-if)# ip nat inside
(conifg)# ip access-list 100 192.168.0.0 0.0.0.255 any (Assuming 192.168.0.0/24)
(config)# ip nat inside source list 100 interface (WAN interface) overload
Unread 29-12-2016, 17:28
Scott L.'s Avatar
Talking Re: Internet help
(Inside interface)
you are correct that Nat would be the same. I don't think I need nat on the cisco router, because I have 5 public IP addresses, which are split between two downstream sophos UTM firewalls, which provide the Nat to the internal networks.
I am having trouble simply establishing the pppoe connection for the dsl at the moment.
