Go to Post I suggested it in brainstorming, but then people threw things at me. Apparently there ARE bad ideas in brainstorming. - Kevin Sevcik [more]
Unread 24-12-2016, 06:03
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
pic: FRC KOP Chassis Butterfly Upgrade V1
Unread 24-12-2016, 06:06
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: pic: FRC KOP Chassis Butterfly Upgrade V1
Love the use of 3112T31. Almost perfect COTS; just need to drill out the 1/4-20 thread and tap 5/16-24.
Are those cylinders strong enough? There will be side loads ....
Richard Wallace
since 2003
Unread 24-12-2016, 09:12
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Would really love to see a parts breakdown, and a cad for the modules and where in the chassis they attach. I love the idea of making the kop chassis upgradeable!! Hopefully Andy sees this thread and gets up with the op on the design. Would be an outstanding option to have available for teams.
Unread 24-12-2016, 10:05
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Each one, with some wiggle room, should lift about 45 lbs at 110ish psi. Side loads shouldn't be an issue do to the lack of hard mounting on the rod. Using the lifting eyes should just allow it to slip, right?
The amount of lever arm that is created by the module with only one mounting point in sheet metal would be a bigger concern to me. Then again, maybe the omnis won't allow much side load due to the fact that they are omnis...
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 24-12-2016, 10:21
dradel's Avatar
But you only have 60 psi to use.
Unread 24-12-2016, 10:36
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
[I am assuming that the butterfly pivot point is at the axis rubber tread wheel; if it's anywhere else, please disregard.)
I agree about the side loads (and won't those be minimal with the omni wheels in the first place?), but max FRC working pressure (caveat rule changes) is 60 psi, reducing the lift to about 26.5 lb. As this is applied at a lever arm nearly twice the distance from the pivot, this should be enough.
Unread 24-12-2016, 13:13
Nubs are cool. I generally favor using FTC parts in FRC when it is feasible.
However, in this application I would replace them with flange nuts like these, and use 3/8" bolts for both omni axles and lift points.
Richard Wallace
since 2003
Unread 24-12-2016, 14:30
Man I was feeling good about my ability to do math in my head... turns out you have to start with the right numbers.
Andrew Basse
Unread 26-12-2016, 12:56
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
Nice Design and modification of an existing chassis. I like the idea a lot, but I have a few comments on this implementation:
What do you use for chain/belt tensioning? as far as I can see there is none yet, which will lead to problems.
Right now it looks like the Chain you use to go from wheel to omni wheel is larger than the diameter of the wheel. The sprocket is just under the wheel, so the chain will certainly be touching the carpet. This would be bad for several reasons, the least of which is it is currently illegal to have metal touching the carpet.
Finally I think the plates you use to attach the omni wheel to the standard wheel are too weak. There is almost nothing keeping the two plates from parallelogram-ing. You have defined them so they remain parallel, but when the feel large sideways loads they will move to be a parallelogram instead of a rectangle. This wouldn't be too much of a problem except for the fact that you have chain running through these, so if it parallelograms while you move, it is a recipe for the chain to jump.
These are just some thoughts I had after looking at the grabcad for five minutes, so it is very possible I am wrong. This is just my gut reaction after looking at the design.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 30-12-2016, 06:45
fargus111111111's Avatar
fargus111111111 fargus111111111 is offline
AKA: Tim W
FRC #0343 (Metal in Motion)
fargus111111111 is on a distinguished road
As far a belt tensions, the kit bot doesn't have them and if this is using the same geometry I see no reason for it to need them, the chain I'm not sure about.
If I understand the design correctly the outside plate of the kit base would still be included and that would prevent the modules from parallelograming.
Overall I like the design and the idea of being able to upgrade the kit is something I've wanted to do for a while.
I didn't break it... this time.
