Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 12-24-2016, 04:25 PM
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Andrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud ofAndrew_L has much to be proud of
Re: pic: MVRT Off-Season Sheet-metal Chassis
A few tips:
-Close the box sections for the frame, it'll make them significantly stronger.
-Add in a bellypan, it'll help with torsional stiffness
-The split front part isn't very rigid either - extra support there (+bellypan) can help with that.
Check out some of 971's drivetrains for some good methods of sheet metal implementation. There are some helpful rectangular and octagonal drivetrains in the 2015 section that you should definitely check out.
